LS distributer?
Old Mar 20, 2008 | 11:30 AM
krazeenoy's Avatar
Default LS distributer?
anyone know if an LS distributer will fit a gsr motor?
Old Mar 20, 2008 | 12:08 PM
NAmodified's Avatar
Default Re: LS distributer? (krazeenoy)
I doubt it, but someone please confirm.
Old Mar 20, 2008 | 12:53 PM
mc-integra111's Avatar
Default Re: LS distributer? (NAmodified)
I don't think so either since the cams are different. You could check the part numbers at http://www.acuraoemparts.com/delray/jsp/home.jsp.
Old Mar 20, 2008 | 12:56 PM
XxNampsterxX's Avatar
I've read somewhere that it will fit, but you have to cut off the bottom leg because it'll hit a sensor.
Old Mar 20, 2008 | 01:14 PM
BoSox46GSr's Avatar
Default Re: LS distributer? (XxNampsterxX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XxNampsterxX &raquo;</TD></TR><TR><TD CLASS="quote">I've read somewhere that it will fit, but you have to cut off the bottom leg because it'll hit a sensor.</TD></TR></TABLE>
I believe I've seen it done but I might be wrong... but unless you're on a real tight budget, I'd suggest just getting the right distributOr.
Old Mar 20, 2008 | 01:36 PM
pokmijn's Avatar
yeah in order for it to fit you must cut off the front bottom bracket. i was using that for a while until i found a vtec distributor.
Old Mar 20, 2008 | 02:23 PM
champLSinteg's Avatar
Default Re: LS distributer? (pokmijn)
I've been using my LS dizzy for over 2 years in my lsvtec. You just have to cut a leg off and it works. No difference in the internals.
Old Mar 20, 2008 | 07:08 PM
krazeenoy's Avatar
Default Re: LS distributer? (champLSinteg)
i see...alright thanks a lot
b16a27
Jan 20, 2006 11:47 AM
DasaEJ1
Nov 5, 2005 06:38 PM
escape2me
Mar 1, 2005 05:16 PM
Rod.
Dec 30, 2004 09:12 AM
Sliced Beard
Jul 17, 2004 10:29 PM
