lowering question...
Old Aug 13, 2003 | 06:34 AM
kaboomin's Avatar
Default lowering question...
ok, so i just got my first teg couple months ago (00' gsr), just got a set of h & R race springs, kyb-agx shocks, skunk2 front camber kit and ingalls rear camber kit that i will be installing tomorrow morning. so i've got 17's right now, will they rub with this drop? anybody else have this setup, how do you like it? also, anybody have any tips or things i should be aware of before doing this install??
Old Aug 13, 2003 | 06:56 AM
fivespeedintegra's Avatar
Default Re: lowering question... (kaboomin)
have fun with the rear LCA bolts
Old Aug 13, 2003 | 06:58 AM
PLRacer's Avatar
theres a good write-up on how to install new springs and struts on team-integra.net
Old Aug 13, 2003 | 07:19 AM
chris215chris's Avatar
Default Re: lowering question... (fivespeedintegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fivespeedintegra &raquo;</TD></TR><TR><TD CLASS="quote">have fun with the rear LCA bolts </TD></TR></TABLE>He's right. I snapped my rear LCA bolt last night trying to install some H&R's. I suggest you have a shop "break" the bolts, so that when you go take them off it won't be hard to do. Trust me, you don't won't to snap that bolt. I still am not sure what I'm going to do about it.
Old Aug 13, 2003 | 07:35 AM
mowry's Avatar
If you've already broken the bolt, the only reasonable thing I've been able to do is torch out the whole bushing (use a torch to melt the rubber) then cut the bolt and replace the bolt and bushing. Not pleasant, but it does work.
Good luck!
Matt
Old Aug 13, 2003 | 07:47 AM
kaboomin's Avatar
Default Re: lowering question... (mowry)
just talked to acura and they're going to break my rear bolts for me, providing everything goes good they said it'd be like $40, which sounds like it's worth it from what you guys are saying,,,
thanks for the info!
Old Aug 13, 2003 | 10:13 AM
detaude's Avatar
How much do shops usually charge anyways to install suspension stuff?? Including camber and everything?
Old Aug 13, 2003 | 11:06 AM
kaboomin's Avatar
Default Re: lowering question... (detaude)
most shops around here won't touch it, found 2 shops that would and they were talking like $500 to install springs, shocks, camber kits and adjust the camber, pretty much the whole nine yards,,, i thought that was alittle steep, but 2 shops quoted me the same,,,,, i've got a hydro-spring comp. so if i can get the bolts off it shouldn't be to hard of an install, i think anyways.
Old Aug 13, 2003 | 11:59 AM
Hites
Guest
Posts: n/a
jesus, $500!? i would just read up on it and do it myself.
Old Aug 13, 2003 | 12:07 PM
kaboomin's Avatar
Default Re: lowering question... (Hites)
i'm doing it myself fo sho!! got plenty of other mods i'd like to spend my money on other than labor
Old Aug 13, 2003 | 12:11 PM
kaboomin's Avatar
so i'm assuming that i shouldn't have a problem with my wheelz rubbing with this drop?
Old Aug 13, 2003 | 01:43 PM
NightRiderS2K's Avatar
In-N-Out Burger
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaboomin &raquo;</TD></TR><TR><TD CLASS="quote">so i'm assuming that i shouldn't have a problem with my wheelz rubbing with this drop?</TD></TR></TABLE>
What size tires? Do you still have the fender linings inside your car? You can always roll the fenders in the back to avoid rubbing there . Go to a shop and have them break the rear LCA bolt, but you can do it yourself...a Breaker bar, a pipe to extend the breaker bar handle-length and muscles are what you need to break that sucker. Anyways, please post a pic when you're done, I would like to see how much it dropped your car. Just curious you know...
oo.02--cheeers--
NRG
Old Aug 13, 2003 | 02:01 PM
kaboomin's Avatar
Default Re: lowering question... (NightRider-gsR)
i've got 40 series tires, i'm bringing it in to have the lca's broke for me at the dealership, heard too many horror stories with breaking em and shiit..
Sam268
Sep 9, 2004 03:48 PM
JamesQ
Oct 20, 2003 11:24 AM
SD_EM1
Oct 3, 2003 08:50 AM
