Lowering car
Old 05-27-2005, 02:57 PM
Presto800's Avatar
Default Lowering car
Best way to lower? not asking for much, few inches....
Cut the springs ? Bad, but cheap...
Buy springs... Expensive, but smooth ride...
Which one would be worth it? And if i should buy springs, what's the best affordable kind?
Im a noob at this stuff >_< Any help is appreciated!
Old 05-27-2005, 03:48 PM
That's what she said!
Dforce's Avatar
Default Re: Lowering car (Presto800)
Cutting the springs will cost you in the long run, cuz you'll mess up your shocks.
Buy some Tein springs ($125) or some Progress springs ($140).
Old 05-27-2005, 03:49 PM
Presto800's Avatar
w00t thank you for the feedback :D
Dforce's Avatar
Default Re: (Presto800)
Whats your budget?
Old 05-27-2005, 03:51 PM
Presto800's Avatar
i have about 300bucks to blow on springs...
Old 05-27-2005, 04:02 PM
わたしは。。。
E.J.'s Avatar
Just get GC coilovers, should be able to find one under $300
Old 05-27-2005, 04:04 PM
IntegraCF21's Avatar
You could also get some Ground Control or Skunk2 coilovers for less than $300. But I would highly recommend that you also get struts as well because your stock ones won't last long if you don't. I have the Skunk2's and Koni reds, which was $570 and couldn't be happier.
Old 05-27-2005, 04:32 PM
Stoic's Avatar
you will need to buy aftermarket shocks because if you lower your car on stock shocks, you will blow them in less than a year. usually a good spring/shock combo runs for around $500. If you don't ever want to have to worry about springs sagging or shocks blowing, buy a full coilover system but it will run you at least $700 usually
ej8ray
Suspension & Brakes
05-28-2011 09:09 AM
alex14
31
01-30-2011 11:03 AM
wako182774
09-11-2005 02:22 PM
indy90turbocrx
07-31-2004 01:40 PM
Quick Reply: Lowering car
