lower control arm bolt
Old Aug 19, 2004 | 05:39 PM
nalgas's Avatar
Default lower control arm bolt
94' integra rs model lower control arm bolt will not come loose. head breaks off. I cut the bottom of the strut off so i could take it out now i have a bolt stuck in there. is this a bolt or a solid peace of metal stuck in the control arm because now i can not get it out
Old Aug 19, 2004 | 05:46 PM
Train's Avatar
Default Re: lower control arm bolt (nalgas)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nalgas &raquo;</TD></TR><TR><TD CLASS="quote">94' integra rs model lower control arm bolt will not come loose. head breaks off. I cut the bottom of the strut off so i could take it out now i have a bolt stuck in there. is this a bolt or a solid peace of metal stuck in the control arm because now i can not get it out</TD></TR></TABLE>
you cut the strut?? can you take a picture of what you cut and post it? it is a bolt that connects the LCA to the knuckle. not welded in or anything. did you try pb blaster, wd-40, etc? or possibly heating it with a torch? or if it's rusted, hitting the rust loose with a hammer?
Old Aug 19, 2004 | 05:50 PM
nalgas's Avatar
Default Re: lower control arm bolt (Train)
ya i cut it off! i tryed all those methods. now im stuck with this headless bolt in the control arm.
Old Aug 19, 2004 | 05:51 PM
gsrboi80's Avatar
those bolts r notorious my friend. Everybody has a problem w/ them they break, strip and sieze to the bushing. You need to drill out the bolt u broke off in there get new lca bolts and your probably gonna need new bushings. Next time use air tools if u have accses to them. Those bolts suck dude good luck.
Old Aug 19, 2004 | 05:53 PM
nalgas's Avatar
Default Re: lower control arm bolt (gsrboi80)
im at my shop and i used air tools. u got a rough idea on prices for that ****
Old Aug 19, 2004 | 05:58 PM
[ iLL ] iNt3GrA's Avatar
i snapped mine got SRR LCA's
Old Aug 19, 2004 | 06:00 PM
nalgas's Avatar
Default Re: ([ iLL ] iNt3GrA)
how much those run
Old Aug 19, 2004 | 06:10 PM
3.504's Avatar
Default Re: (nalgas)
go to acura, get a new bushing+bolt. go to machine shop, ask for them to press out old one/press in new one. that should all cost under $30-$35.
Old Aug 19, 2004 | 06:11 PM
jweezy225's Avatar
snapped the same bolt u did today, just drove home on it... tomorrow im going to start thinking how I can fix this
*edit* [ iLL ] iNt3GrA WHO ARE YOU? lol
Old Aug 19, 2004 | 06:14 PM
jweezy225's Avatar
Default Re: (3.504)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3.504 &raquo;</TD></TR><TR><TD CLASS="quote">go to acura, get a new bushing+bolt. go to machine shop, ask for them to press out old one/press in new one. that should all cost under $30-$35. </TD></TR></TABLE>
machine shop?
Old Aug 19, 2004 | 07:19 PM
chrisnova's Avatar
I have never come accross a lower control arm bolt that could not be freed up by a 5-10 minutes with a propane torch. Make sure to nail the bolt with the blue flame where it is sticking for 5-10 minutes. That is gauranteed to break the rust bonds if you apply the correct amount of heat to the right place. Try it again and you should get it free. It requires less effort if the car is less than 10 years old.
Old Aug 20, 2004 | 04:18 AM
boosted k20's Avatar
Default Re: lower control arm bolt (chrisnova)
if u use the torch to free up the bolt, ur most likely gonna have to replace the Lower control arm bushing. but if the torch method works to free up the bolt, then go ahead and do it. if the bolt comes off fine then ur only problem is press n in a new bushing. thats less work than cutting the bolt off and pressing in a new bushing.
the hardest part about redoing the suspension in the rear are those damn LCA bolts.
Old Aug 20, 2004 | 09:47 AM
3.504's Avatar
Default Re: (jweezy225)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jweezy225 &raquo;</TD></TR><TR><TD CLASS="quote">
machine shop?</TD></TR></TABLE>
any competent shop with a press will work fine. i used a machine shop before cause they're good guys and only charge me $5
Old Aug 20, 2004 | 02:16 PM
integralicious's Avatar
Default Re: (3.504)
dont use a torch on it, it only makes things worse off and more expensive. The main goal is to save the bushing. Your best bet is to use an air chizel. (this didnt screw up my bushings) When this happened to my car while I was installing new suspension on my 94 Ls the front bolts came out fine but the back gave me trouble. I snapped my bolt nontheless. To getta new bolt, go to an acura or honda dealer theyll know exactly what your talking about becuase these bolts are the devil. Make sure after you pop it out with the air chizle that you put anti-seize on the new bolt so you dont run into the same problem. I know exactly what your goin through and its a pain.
lemme know how you make out, by the way what were you changing down there?
Old Aug 21, 2004 | 07:56 PM
im Ernest, who r u? what color teg u have?
i got the SRR's from a guy named will off of the boards good price do a search for SRR and you can find his post.
Old Aug 21, 2004 | 08:03 PM
Badger401's Avatar
I had the same problem with my car, you shouldn't have cut the strut though, you should have just popped the hatch and removed the 2 nuts that hold the top of the strut on, thats what i did, and then i had to cut the bolt off and i went to menards and got a new bolt and nut of the same size and it works fine
Old Aug 21, 2004 | 08:30 PM
Radon_03's Avatar
Default Re: (Badger401)
go press that bushing out, replace it and get a new bolt. Use some 3M copper anti-seize when you put the new bolt in. Hopefully that will help keep it from seizing the next time you have to do something. Had the same probem with mine, pressed it out and replaced the bushing and bolt. $20 for bushings from http://www.suspension.com. good luck
Old Aug 21, 2004 | 08:41 PM
IVI's Avatar
IVI
Default Re: (Radon_03)
grind away the bolts in between the struts and your control arm will be free with the bushing with the bolt still in it. take it to a machine shop or any shop with a hydraulic press and they can press out the old one and press in the new one.
if you damaged the bolt on the end of the strut itself, goto home depot and get a simliar bolt.
FrontwheelENT
26
Jul 23, 2012 01:22 PM
cletus11
Mar 6, 2011 02:17 AM
DMCCOY
Suspension & Brakes
Jun 24, 2007 03:05 AM
Mr.Death
Jan 9, 2007 10:19 AM
95LStizzy
Feb 1, 2006 04:58 AM
