Low Idle when A/C is on
Old Apr 26, 2004 | 11:54 PM
ej1times's Avatar
Default Low Idle when A/C is on
My brother has a 1990 DA with a B18C1. It idles at 900rpm but when the A/C is turned on, idle drops down to 100rpm and car feels like it's going to stall. Do you guys have any ideas on why the idle drops so low? Thanks.
Old Apr 27, 2004 | 01:52 AM
giff74's Avatar
Default Re: Low Idle when A/C is on (ej1times)
I dont have the answer, but mine has been doing the same thing. I have a b16a1 in my 91 DA, maybe they dont like swaps??
Old Apr 27, 2004 | 10:15 AM
frenchy's Avatar
Default Re: Low Idle when A/C is on (giff74)
iacv - its either bad or when you installed the tb you covered the hole w/ the gasket(thats what i did)
Old Apr 27, 2004 | 10:39 AM
turbotommy's Avatar
Default Re: Low Idle when A/C is on (frenchy)
^true
the reason is that the ac puts more strain on the eng when its on since the pulley is engaged.
i would also check you belt tension form the crank pulley to your ac compressor.
Old Apr 27, 2004 | 11:08 AM
integraL's Avatar
Default Re: Low Idle when A/C is on (turbotommy)
yeah this is a common problem for hondas. in my old civic, when i would unlock the power locks, the RPMs would fluctuate
Old Apr 28, 2004 | 12:13 AM
ej1times's Avatar
Default Re: Low Idle when A/C is on (integraL)
thanks guys. I'm going to check the belt tension, I think that is the problem but I'll check out the TB too.
Old Sep 16, 2004 | 08:29 PM
IMALLSLO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by giff74 &raquo;</TD></TR><TR><TD CLASS="quote">I dont have the answer, but mine has been doing the same thing. I have a b16a1 in my 91 DA, maybe they dont like swaps?? </TD></TR></TABLE>
Find a fix for this one? Brother has the same problem with a91 d, b16a,pr3 ecu and im still looking for a fix. Find anything?
jdm samurai
Jul 12, 2006 07:46 AM
axtran
Jul 7, 2006 09:05 AM
effinnwackk
18
Sep 9, 2004 08:25 AM
JDM97R
Aug 7, 2004 11:59 AM
BB6 SH
Nov 17, 2003 04:30 AM
