low idle
Old Mar 30, 2006 | 04:09 PM
b18hondaacura's Avatar
Default low idle
ok i have a 97 teg mods are stage 1 turbo cam, dc 4 into 1 header, cold air,2.25 ex with magnaflow muffler. my car idles around 700 and drops to 400-500 and back up to 700 and back down. please help
Old Mar 30, 2006 | 04:38 PM
Default Re: low idle (b18hondaacura)
bump
Old Mar 30, 2006 | 04:57 PM
Sleeping_H22_DC2's Avatar
probably a vacuum issue that where i'd put my money on !
Old Mar 30, 2006 | 05:02 PM
c1_sleeper's Avatar
you might need a valve adjustment. thats how my car idles as well and i know my valves need to be adjusted
Old Mar 30, 2006 | 05:09 PM
sik96teg's Avatar
Default Re: (c1_sleeper)
yea id say valve adjustment too what did u set the valve adjustment to when u put in those cams some cames us different specs then oem
Old Mar 30, 2006 | 05:16 PM
Default Re: (sik96teg)
well i just droped the cams in and advanced timing
Old Mar 30, 2006 | 06:17 PM
Usagi Yojimbo's Avatar
From: Dont say my car is topless say the titties is out
Default Re: (b18hondaacura)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleeping_H22_DC2 &raquo;</TD></TR><TR><TD CLASS="quote">probably a vacuum issue that where i'd put my money on !</TD></TR></TABLE>
It could also be your throttle positioning sensor, Idle Air control Valve, or Low coolant would also make your car idle up and down.
Old Mar 31, 2006 | 04:09 AM
sik96teg's Avatar
Default Re: (Usagi Yojimbo)
if u jus dropped the cams in there then u need to do a valve adjustment find out what they need to be adjusted to from the place u got the cams.
Old Mar 31, 2006 | 02:58 PM
2000GSR2432's Avatar
Are you tuned? I have had the greddy emanage tuned with my car, i have skunk2 stage 1's, it idled fine, ever since the hondata was put on my car does the same there, it bounces from 500-800, my cousin has the same problem. Maybe its a hondata thing.
Old Mar 31, 2006 | 03:47 PM
jega4ever's Avatar
You also might want to try cleaning your FITV (Fast Idle Thermo Valve)..
Reasons why you should take it apart and clean it:
-High idle before your car warms up
-Lumpy idle
-Roaming idle
-Hunting idle
-Fluctuating idle
quick99gs-r
May 25, 2009 06:35 AM
DaYZeD.1
Apr 19, 2008 03:07 PM
Mr2KiEu
Apr 5, 2005 11:56 PM
Mr.Dew
Sep 6, 2004 12:51 PM
ATS*Mark
16
Feb 22, 2004 01:00 PM
