Looking for complete shift linkage!?
Hey guys. Car is down and need to get parts. I need a b series shift linkage. The rod that goes to the front and bolts onto the tranny with the 12mm nut and the round poly bushing came off and got bent during driving. Car is towed. I want to get a complete b series linkage. With a shifter. Done out the box. And install it. Any ideas? I checked hasport, doesn’t come with shifter etc. any ideas? Should I get a used linkage off fb marketplace? I just don’t want any gear slop. Also, would it be difficult to get a linkage and then a shifter and put that together? Would someone be able to give me links to each item. Need this to be easy. Thanks guys. Im open to any brand or style.
Hammer it back into shape and send it.
Or rebuild the entire shift linkage, pull up the parts diagram and buy all the little plastic and rubber bits in the shift lever, poly shifter bushings, buy a new rod with the U joint its like $70, and buy a replacement for the bent part from FB, junk yard, etc.
egvtec
Apr 27, 2012 12:30 PM
wrx'n you
Feb 23, 2007 08:47 PM
