leak down compression test
Old Aug 21, 2007 | 12:52 PM
sinister357's Avatar
Default leak down compression test
my gsr consumes oil so i'm considering doing a compression and leak down test. the compression test i can understand - using a guage attached to the spark plug hole. but the leak down... what is that? how do i test that and with what tools?
Old Aug 21, 2007 | 01:04 PM
Padawan's Avatar
Darth ModerVader
Default Re: leak down compression test (sinister357)
Well, first I'd do the compression test. I'd do it twice -- once "dry" and then once using a teaspoon of motor oil poured into each cylinder through the spark plug hole. This will help give you an indication of whether the piston rings are your problem. After you get those results, you may or may not want to continue with a leak down test. Here's a link to the procedure, but you can also find others by searching Google: http://www.carcraft.com/techar....html
Old Aug 25, 2007 | 10:05 PM
HmgLauj69's Avatar
after doing a wet and dry comp test if your numbers about the same have a buddy drive behind you on the free way and punch it and let it coast. right when it coast if blue smoke comes out your going to need new valve seals, or maybe valve guides (highly unlikely)
SilkyJohnson
13
Feb 15, 2011 05:54 PM
humboldt_skim
May 31, 2008 08:18 AM
1badteg
Jul 16, 2007 02:00 PM
Sport_Injected
Aug 16, 2004 09:06 PM
Propulsion
Jun 5, 2002 11:48 PM
