Is this a leak?
Old May 23, 2003 | 08:02 AM
Vic Nyce's Avatar
Default Is this a leak?
disregard the liberal amounts of instagasket but is that a crack in my header [cyl 3]? if so, can it be JB Welded or can i dab on some copper silicone? tia
Old May 23, 2003 | 08:13 AM
sshaikh01's Avatar
Default Re: Is this a leak? (Vic Nyce)
what crack
metal-x's Avatar
what kinda header is that looks ghetto
Old May 23, 2003 | 08:21 AM
ebelp's Avatar
I don't see a crack, but if there is one, you can use this:
Old May 23, 2003 | 08:32 AM
Vic Nyce's Avatar
Default Re: Is this a leak? (ebelp)
thanks i dont see one either but there looks to be smoke coming outta there by looking at the darkened area above the tube. i can also smell it when im at a standstill. where can i pick up the inferno stuff? according to the guy i got the car from its a Focuz header.
Old May 23, 2003 | 10:06 AM
sshaikh01's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vic Nyce &raquo;</TD></TR><TR><TD CLASS="quote">thanks i dont see one either but there looks to be smoke coming outta there by looking at the darkened area above the tube. i can also smell it when im at a standstill. where can i pick up the inferno stuff? according to the guy i got the car from its a Focuz header.</TD></TR></TABLE>
Seems like you have a leak not a crack.
Old May 23, 2003 | 10:59 AM
WiggiE's Avatar
New User
Default Re: Is this a leak? (sshaikh01)
Take that header off and scrape all that **** off the header and head. Get it good and clean and put and OEM gasket in there. Torque the bolts down to spec, which I forget at the moment, and be good to go.
Old May 23, 2003 | 11:16 AM
TeamSTEALTH GSR's Avatar
Default Re: Is this a leak? (WiggiE)
23ft-lb
Old May 23, 2003 | 12:37 PM
IntEGNYC's Avatar
Default Re: Is this a leak? (TeamSTEALTH GSR)
Crack kills...
Can you circle the area in the photo you are referring to?
Old May 23, 2003 | 01:50 PM
fivespeedintegra's Avatar
Default Re: Is this a leak? (IntEGNYC)
i think he means this spot right here....
looks like it is leaking at the weld....if that's the spot you're talking about....cause look at the pipe to the left of it and you see no black carbon on it.
Old May 23, 2003 | 02:40 PM
Turbo Powa's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WiggiE &raquo;</TD></TR><TR><TD CLASS="quote">Take that header off and scrape all that **** off the header and head. Get it good and clean and put and OEM gasket in there. Torque the bolts down to spec, which I forget at the moment, and be good to go.</TD></TR></TABLE>
Old May 23, 2003 | 05:23 PM
DK4200's Avatar
Default Re: Is this a leak? (Panda EK)
WTF kinda cob job is that?!?!?! i don't see any crack, do what the guy above said and scrape that crap off and buy a damn gasket
Old May 23, 2003 | 06:43 PM
iH8RICERZ's Avatar
Default Re: Is this a leak? (DK4200)
OT but is that a 94 GSR motor?...built in Japan in 93..but is your car a 94 gsr?
Old May 23, 2003 | 07:27 PM
Vic Nyce's Avatar
Default Re: Is this a leak? (iH8RICERZ)
thanks for the replies guys. the guy that had the car before me made the mess with the header gasket. i'm gonna get the proper gasket for it soon tho.
i believe u are correct. 94GSR engine built in JDM land in 93. the block stamp says B18C1. JDM would be just B18C correct?
Old May 23, 2003 | 07:29 PM
B2FiNiTY's Avatar
JDM is B18C correct.
NorCalAllMtr408
55
Mar 18, 2007 04:53 PM
Duck Sauce
Jan 30, 2007 04:48 PM
allmotorcrx2001
Dec 31, 2006 10:35 AM
TsukubaSpec
20
Aug 13, 2005 02:07 AM
Shaun
Oct 12, 2004 10:45 PM
