knock sensor -> lose hp?
was reading somewhere that the knock sensor can slow timing down
even with little vibration; and lose hp (~10hp) that way??
Is this true?
My JDM engine was throwing codes; knock sensor from my GSR was swaped in..
wondering if this is hurting me? should I unplug and just take the CEL?
Is this true?
solution is to unplug than?
had to use a USDM ecu..so it required it..prob could have
avoided a lot of headache if i stuck with the JDM ecu for which
I needed a harness..
this is a JDM type r engine..
Modified by voltageGSR at 11:27 PM 12/20/2003
It takes more than a little vibration to get knock retard. You should definitely find out if you are getting false knock readings or if your engine actually has a problem. DO NOT run without the sensor installed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by voltageGSR »</TD></TR><TR><TD CLASS="quote">solution is to unplug than?
I needed a harness..</TD></TR></TABLE>
Every ecu needs the knock sensor period. JDM or USDM. Doesn't matter.
And if you unplug the knock sensor, your ecu will have no idea if you're knocking like crazy or not knocking at all, and in order to keep itself from exploding, it'll do the same changes as if your knock sensor was detecting knock.
The solution is to tune the engine so that you don't knock. Thats it. Only solution.
Modified by voltageGSR at 11:27 PM 12/20/2003</TD></TR></TABLE>
knock sensor can be tuned with new v-afc II !
if you don't mind me asking how much did you pick up the VAFCII for
and from where?
I saw your mod list; wondering what exactly the VAFC will allow you to do;
and how much gain do you expect? are you tuning yourself or having a shop do
it?
thanks!
and from where?
it?
thanks!
I thougght that only certain ECU's have the knock sensor feature. When you tune a car the tuner usually unplugs it. I know that the P72 ecu has a knock sensor and the P28 doesnt. There are alot of people who run with the P28 ecu. I just got hondata with a P28 chip and still need to order a P28 sockted ecu. Ive heard that some aftermarket pistons can cause the knock sensor to go off and retard timing bcause they are noisy.
i have stock pistons for now .. so shouldn't set it off
i read you can chip so that the knock sensor won't go off -
and can also adjust using s-vafc II (new)
i want to upgrade the internals of my ITR so I can run
higher boost when I get turbo this spring. Thinking about sleeving;
pistons; stock arm; toda b cams
any other recommendations?
anyone know with good tuning how much boost I can run on
stock JDM ITR safely?
peace.
peace.
hmmm... I havent heard of the "s-vafc2", but that would be nice. The VAFC allows you to add or take away fuel at any rpm. Im gonna get it tuned on the dyno because it requires a wideband o2 sensor to accurately change the fuel curve to run a stoich ratio across the board (or slightly richer is good!)
It also allows vtec changeover adjustment and other minor functions... alot of eye candy until you do enough mods to require fuel adjustment.
Picked it up off Ebay for $300 shipped, there some guy on there with a flood of safc2's and vafc2's for cheap.
nice; have to pick one up..like you said; need enough mods to
make a difference first
who do you trust to do this tuning for you on the dyno..unfortantely
being in cleveland hurts when it comes to that..plus i'm still learning..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Devlins 91LS »</TD></TR><TR><TD CLASS="quote">
The solution is to tune the engine so that you don't knock. Thats it. Only solution.</TD></TR></TABLE>
To the best of my knowledge...only VTEC motors required the knock sensor. Except for the 92-95 Civic EX. somebody correct me if I am wrong...but I'm pretty sure that is accurate.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by urbanracer98 »</TD></TR><TR><TD CLASS="quote">
To the best of my knowledge...only VTEC motors required the knock sensor. Except for the 92-95 Civic EX. somebody correct me if I am wrong...but I'm pretty sure that is accurate. </TD></TR></TABLE>
Yup, not all engines come equiped with a knock sensor. Not sure where he got the "every ECU NEEDS a knock sensor" stuff.
the knock sensor does not lower HP if retarding timing as it can only function to 5000rpm, unless you make peak power at 5000rpm, you will not lose power. to disconnect the knock senor you do not unplug it anyway you ground it out. very badly maintained cars will trip the knock sensor, anyone who builds a motor would omit the knock sensor or find one that filters out the sound of piston slap, preignition is different than slap sound.
so in all reality, because the v-afc2 has no knock sensor, everyone should buy a "first gen" v-afc and then a s-afc2 and use the v-afc JUST for vtec... hmm, expensive
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StyleTEG »</TD></TR><TR><TD CLASS="quote">
Yup, not all engines come equiped with a knock sensor. Not sure where he got the "every ECU NEEDS a knock sensor" stuff.</TD></TR></TABLE>
Crap thats what i meant. all VTEC engines use one.
Then i remembered the p28 didn't use one. So i correct my previous statement and it should read "Any VTEC ecu with the exception of the p28 uses the knock sensor. JDM or USDM."
93(Civic)EG6
Sep 28, 2006 01:43 AM
Team 4
Aug 4, 2004 04:53 PM
