knock sensor code (23)
Old Feb 22, 2014 | 06:55 PM
Spoolinls's Avatar
Default knock sensor code (23)
i picked up a 96 integra ls auto that was converted to manual it has a 100% stock gsr in it. Long story short i picked it up and it had a ks (23) code. I pulled the motor and re gasket it while it was out i replaced the knock sensor but the code keeps coming back. Doesn't do it when at idle only after it has been driven awhile. I checked the wiring going to it and it looks fine any suggestions
I have changed ecu to see if that was the issue
i plugged in the verus at my work and show live data of the knock sensor which is showing that it is working fine. If i back out to check out live codes and it says there isnt any present codes but the light it on on the dash
I seen that my primary o2 sensor was dead showing no activity so I replaced it thinking it may be leaning the car out to much but it still came back on
Old Feb 22, 2014 | 07:01 PM
B_Swapped93's Avatar
Default Re: knock sensor code (23)
you re-set the ECU right ? does the car feel low on power/jerking when the light is on and you're driving it with it on ?.
Old Feb 22, 2014 | 07:06 PM
Spoolinls's Avatar
feels fine no lose of power or anything. I haven't drove it in a month since I re did the motor but I drove it to work today and about a mile from work it came on checked the code (23) reset it even tried a different ecu
Old Feb 23, 2014 | 06:10 AM
Spoolinls's Avatar
Bump
Old Feb 23, 2014 | 07:45 AM
tamboo's Avatar
10 Year Member
tested the wires with an ohm meter? eyeballing them doesnt count.
Old Feb 24, 2014 | 03:19 PM
Spoolinls's Avatar
Ok looks like they never wired it up I looked at the pin out on the ecu and there is a red/blue wire that is cut so I will wire it up tomorrow. How could I get a reading off it if I wasn't wired up
Old Feb 24, 2014 | 03:53 PM
Spoolinls's Avatar
Old Feb 24, 2014 | 04:05 PM
huh ? are you asking how you GOT a reading or how to GET a reading on it in it's current state.
Old Feb 24, 2014 | 04:19 PM
Spoolinls's Avatar
How I GOT
Old Feb 24, 2014 | 04:22 PM
Knock sensors are "piezoelectric" so lets say you have it unplugged and tap it on the table it will give off a reading ! neat little fact about them.
Old Feb 24, 2014 | 04:25 PM
Spoolinls's Avatar
So that wire lead off the connector is reading vibrations off the floor board?
Old Feb 24, 2014 | 04:34 PM
off the knock sensor it's self
Old Feb 24, 2014 | 04:45 PM
Spoolinls's Avatar
The reading I was talking about is I have a verus scanner at work which plugs into the obd port and I was seeing live data on the knock sensor and it was showing movement. So how would I of got a ready off that if it isn't even wired to the ecu
Old Feb 24, 2014 | 04:54 PM
maybe it's grounding off something wire it up and see
davidu
23
Oct 15, 2008 06:30 PM
Jonzo
Jun 25, 2005 11:28 AM
calgone47
Oct 6, 2004 11:46 AM
stephenB!
Mar 12, 2004 06:33 AM
TRhatchCRAP
10
Aug 10, 2003 11:52 AM
