Jun3
I know this. I will be using either Crower or Jun Valvesprings and retainers. The Ecu will be a Mugen Program. Also will have a Skunk2 Intake manifold.
Also was thinking about adding JDM ITR pistons, and some type of 5 bolt cam gears.
use the JUN valvesprings, and use portflow retainers for cost.
and use both JUN3 cams.
or buy it as a whole package. then you can work on your bottom end next.
or your valuable high lift cams won't be used to its full potential
why a mugen ecu?if your gonna spend the money get JUN's ECU and JUN's valve train with the mugen you will still have to tune and have a vtec controller to change that low crossover
Have a VAFC. I was gonna go with a "programmed" ecu. Sorry for the confusion. I freind told me that a few people were using the JUN2 and 3 intake cam and a ITR exhaust cam and making some amazing power. Must have heard wrong.
Some motors won't react the same way.
Gotcha...thanx for the Info i really appreciate it!
anyone running the set up im thinking of running? WHat cams do you have and what kinda power are you making to the wheels?
[Modified by Big Carbon, 2:42 PM 2/6/2002]
iH8RICERZ
22
Jan 5, 2005 05:22 PM
