Jacking up Car // Alignment
Old Nov 7, 2005 | 12:53 AM
J.nguyen's Avatar
Default Jacking up Car // Alignment
Well, i have 94 Acura Integra dropped and my alignment is off... im thinking about doing alignment and adjust my sk2 camberkits , but im going to be jackin up my car and working on it down the line alot in the next couple months... soo does jacking up the car mess up ur toe or whatever ... and should i even get it aligned b/c i heard jacking up ur car screws up your alignment ..
Old Nov 7, 2005 | 06:08 AM
PrinceAli132's Avatar
Default Re: Jacking up Car // Alignment (vietblood129)
Jacking the car up will not affect your alignment. The only way your alignment gets screwed uo is when you tweak or adjust the suspension and any of its components, or if you hit a really bad pot hole etc. Jacking up your car, taking off your tires will not mess anything up.
Ali
Old Nov 7, 2005 | 09:44 AM
Circuit Star-29's Avatar
Default Re: Jacking up Car // Alignment (PrinceAli132)
FYI...when doing your own alignement, drive the car onto ramps or stacked boards...you'll need the suspension loaded for a proper alignement.
Old Nov 7, 2005 | 01:57 PM
J.nguyen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrinceAli132 &raquo;</TD></TR><TR><TD CLASS="quote">Jacking the car up will not affect your alignment. The only way your alignment gets screwed uo is when you tweak or adjust the suspension and any of its components, or if you hit a really bad pot hole etc. Jacking up your car, taking off your tires will not mess anything up.
Ali</TD></TR></TABLE>
are u sure?? how come alot of ppl tell me jacking ur car up with a stock jack or pump jack on one side only messes up your alignment..
Old Nov 7, 2005 | 02:13 PM
They're not in the know...they're full of tihs.
Old Nov 7, 2005 | 02:34 PM
J.nguyen's Avatar
Default Re: Jacking up Car // Alignment (C-speed Racer)
soo i should get an ALIGNMENT even though im going to be jacking up my car alot down the line so my tires wont wear out right??
Old Nov 7, 2005 | 03:13 PM
Get an alignement.
Old Nov 7, 2005 | 05:41 PM
2ndName's Avatar
Getting and alignment is very important. Driving the is much more enjoyable.
taimysho0
15
Oct 11, 2023 09:49 PM
whteteg8901
Suspension & Brakes
Apr 6, 2008 09:35 PM
G2_Fella
Oct 6, 2006 05:27 PM
Jaydeep
Sep 15, 2004 11:56 AM
mattcxb18
Aug 12, 2003 06:08 PM
