Itr header problem
Old Dec 16, 2006 | 06:34 PM
GserpleaSR's Avatar
Default Itr header problem
Ok i just install a ITR Replica Header on my 2000 Gsr, the motor has only a Skunk2 intake manifold and a cold air intake. The problem is when i drive it, it feels like i lost power ( No Check Engine Light on! ). Also when vtec hits it feels like it pulls back for a Sec. then the cold air intake does not sound loud like it use to. Thanks For your help!!
Old Dec 16, 2006 | 07:07 PM
GserpleaSR's Avatar
is it normal?
Old Dec 16, 2006 | 07:12 PM
doood's Avatar
been there done that
Default Re: (GserpleaSR)
do you still have the stock ecu?
Old Dec 16, 2006 | 07:13 PM
95 integra's Avatar
It depends, generally you will lose some low end power, however the problem might exist is if you have a bottle neck (like going from 2.5" to 1.8" piping).
Old Dec 16, 2006 | 07:23 PM
GserpleaSR's Avatar
Default Re: (doood)
stock ecu and 2.5'' to stock gsr 2''?
Old Dec 16, 2006 | 07:34 PM
95 integra's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GserpleaSR &raquo;</TD></TR><TR><TD CLASS="quote">stock ecu and 2.5'' to stock gsr 2''?</TD></TR></TABLE>
That can do it. Previously it flowed straight through from the header to exhaust, now it hits that bottleneck and causes a reversion of exhaust gases back towards the head. Thus, you've killed off your exhaust velocity and added disturbance in the flow....thus a lack in power.....or so the *** dyno says.
Old Dec 16, 2006 | 07:41 PM
doood's Avatar
Default Re: (95 integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra &raquo;</TD></TR><TR><TD CLASS="quote">That can do it. Previously it flowed straight through from the header to exhaust, now it hits that bottleneck and causes a reversion of exhaust gases back towards the head. Thus, you've killed off your exhaust velocity and added disturbance in the flow....thus a lack in power.....or so the *** dyno says.</TD></TR></TABLE>
werd. the stock ecu isnt helping matters any either.
Old Dec 16, 2006 | 07:42 PM
GserpleaSR's Avatar
What do you recommend? thanks for the info.
Old Dec 17, 2006 | 12:30 PM
doood's Avatar
at least a 2.5" exhaust and chipped ecu with tuning
Old Dec 17, 2006 | 12:34 PM
95 integra's Avatar
Default Re: (doood)
for under a 200whp NA engine, 2.36" piping is fine, just make sure the merge from 2.5 to 2.36 is smooth.
Old Dec 17, 2006 | 05:23 PM
GserpleaSR's Avatar
Thanks!
shabam
10
Dec 26, 2006 08:35 PM
antivic
Dec 13, 2005 06:53 PM
antivic
Dec 12, 2005 04:42 PM
dgarcia
Jul 15, 2005 05:10 AM
StayTuned12
May 10, 2005 01:03 PM
