ITR Cluster....
Old Jan 8, 2008 | 05:59 PM
BOTAN01's Avatar
Default ITR Cluster....
sup everyone i just swapped out my ls cluster with my new usdm itr cluster. before i installed it my old cluster was at 1/2 a tank, and now with the itr cluster in it is a little over full tank. does anyone know why this might be?
Old Jan 8, 2008 | 06:11 PM
Padawan's Avatar
Darth ModerVader
Default Re: ITR Cluster.... (BOTAN01)
What year is your LS? You most likely just need to swap the green film over from your LS cluster.
Old Jan 8, 2008 | 06:12 PM
BOTAN01's Avatar
i have a 95
Old Jan 8, 2008 | 06:13 PM
Padawan's Avatar
Darth ModerVader
Default Re: (BOTAN01)
Yes, just swap the green film from your LS cluster onto the ITR cluster, and all should be well.
Old Jan 8, 2008 | 06:20 PM
BOTAN01's Avatar
i followed BlueIntegraBoy's writeup https://honda-tech.com/zerothread/1836281
Old Jan 8, 2008 | 06:49 PM
BOTAN01's Avatar
anyone else have this problem
Old Jan 8, 2008 | 07:02 PM
Padawan's Avatar
Darth ModerVader
So are you using the LS green film, or the ITR?
Old Jan 8, 2008 | 07:04 PM
3rdgenintegra48's Avatar
make sure the screws in the back for the fuel guage is really tighten down..the same thing happen to me but with the cold/hot (temperture)gauge
Old Jan 8, 2008 | 07:06 PM
BOTAN01's Avatar
Im using the itr film. as for you 3rdgenin i'll go and make sure the screws are on there tight. i'll let you guys know how it goes
Old Jan 8, 2008 | 07:51 PM
Padawan's Avatar
Darth ModerVader
Use the LS film.
Old Jan 8, 2008 | 07:52 PM
BOTAN01's Avatar
so i just tightened up all the screws again and the gas guage still sits above full. im wondering if i should just fill it up and see if it goes down as the gas goes down. what do you guys think
Old Jan 8, 2008 | 08:43 PM
BOTAN01's Avatar
anyone?
Old Jan 8, 2008 | 08:44 PM
Padawan's Avatar
Darth ModerVader
Default Re: (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">Use the LS film. </TD></TR></TABLE>
Old Jan 8, 2008 | 08:53 PM
BOTAN01's Avatar
what is the reasoning behind this? blueintegraboy said not to do it
Old Jan 8, 2008 | 11:45 PM
Naruto's Avatar
I'm no electronics whiz, but I'd assume if you compared the two, there would be differences. If there are, then those differences could account for why your gas gauge is not working correctly.
*edit* I just read the whole thread, it doesn't say "not to do it" in terms of swapping out the green film. It said he was showing you how to swap the gauges out instead of doing the green film.
Old Jan 8, 2008 | 11:49 PM
DOHCgarage919's Avatar
From: Why To Steal My Car, NC, United States Of America
use the damn ls flim!!! gezzz i did the same thing, listen to padawan, use the ls flim!! damn man so ignorant...
Old Jan 9, 2008 | 12:01 AM
BlueIntegraBoy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BOTAN01 &raquo;</TD></TR><TR><TD CLASS="quote">what is the reasoning behind this? blueintegraboy said not to do it</TD></TR></TABLE>
I never said to use the ITR film. My link shows you how to swap over the gauges, NOT to swap films.
Swapping film method doesn't really work well with 94-97 to 98-01 conversions since the ABS wire is in a totally different location.
You must use your LS film and housing with ITR gauges.
Old Jan 9, 2008 | 01:27 AM
gsrob's Avatar
I followed BlueIntegraBoy's instructions exactly the way he explains it and all of my lights/gauges function correctly. All of the dummy plates need to be swapped around so that the check engine light, low fuel, etc light up in the proper area. You can't go wrong with hid DIY thread for swapping the gauges into the LS housing.
Old Jan 9, 2008 | 02:27 AM
Dilly's Avatar
Default Re: (gsrob)
use the LS film!!!!!!
hahaha.
Old Jan 9, 2008 | 05:19 AM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: (diLLy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrob &raquo;</TD></TR><TR><TD CLASS="quote">I followed BlueIntegraBoy's instructions exactly the way he explains it and all of my lights/gauges function correctly. All of the dummy plates need to be swapped around so that the check engine light, low fuel, etc light up in the proper area. You can't go wrong with hid DIY thread for swapping the gauges into the LS housing. </TD></TR></TABLE>
dude i'm sorry but this is pathetic
padawan told you like 5 times how it fix it, as well as othes, but you got a hard on for this blueballintegra guy....
for being dense
Old Jan 9, 2008 | 11:22 AM
Default Re: (GRAF-FITI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRAF-FITI &raquo;</TD></TR><TR><TD CLASS="quote">
for being dense</TD></TR></TABLE>
You are quoting the wrong person.
Old Jan 9, 2008 | 11:35 AM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: (BlueIntegraBoy)
haha touche
OOPS clicked the wrong post to quote
still....i think you understand who i was referring to
Old Jan 9, 2008 | 11:48 AM
imsickofrice's Avatar
Default Re:
dont know how to read or what? if youre not going to listen to our opinions, then why bother posting up a question?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">What year is your LS? You most likely just need to swap the green film over from your LS cluster. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">[/QUOTE]
[QUOTE=diLLy]use the LS film!!!!!!
hahaha.</TD></TR></TABLE>
Old Jan 9, 2008 | 11:51 AM
92teginsc's Avatar
blueballintegraguy. lmao!! you guys are crazy!! you gotta love that graf-fiti tho. but yeah why doesnt he just use the ls film?
Old Jan 9, 2008 | 01:21 PM
T3@MD3FC*N's Avatar
can u swap 98 ls auto to a itr............?
