ITR BLOCK
just be careful with the spun bearin i just spun a bearin in my ls and the bottom end is completely shot if you get it just make sure the crank and the connecting rod on the spun bearing is good so that way you dont spend 350 to have the block go bad on you later on
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CivicHatch »</TD></TR><TR><TD CLASS="quote">just be careful with the spun bearin i just spun a bearin in my ls and the bottom end is completely shot if you get it just make sure the crank and the connecting rod on the spun bearing is good so that way you dont spend 350 to have the block go bad on you later on </TD></TR></TABLE>
Spend a couple hundred bucks to get the crank micropolished and maybe a new rod if it is that bad. 550-600 and you have a good block that wont go bad on you later on...
if it spun a main bearing, i'd skip it. align honing to fix it can have mixed results. then you run into bearing issues.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by St Jimmy »</TD></TR><TR><TD CLASS="quote">Spend a couple hundred bucks to get the crank micropolished and maybe a new rod if it is that bad. 550-600 and you have a good block that wont go bad on you later on...</TD></TR></TABLE>
i would never reuse a crank that spun a bearing. again, you run into bearing issues. finding another crank would be easier and cheaper.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B.J. »</TD></TR><TR><TD CLASS="quote">Yes the internals may be crap but the block is still good and the pistons are still good</TD></TR></TABLE>
depends on where the bearing was spun
blkDOHCsol
May 9, 2002 07:06 AM
