intermittent CEL
Old Dec 20, 2006 | 06:25 PM
Boots's Avatar
Default intermittent CEL
what could possibly cause an intermittent code 21? im thinking maybe poor connections, its more annoying than anything..any ideas would be great
Old Dec 20, 2006 | 06:56 PM
Boots's Avatar
Default Re: intermittent CEL (boots)
anyone?
Old Dec 20, 2006 | 07:25 PM
95 integra's Avatar
Considering its a single wire connection, its either a bad connection or a bad vtec solenoid....sounds pretty easy to trace down.
Old Dec 20, 2006 | 07:29 PM
Boots's Avatar
Default Re: intermittent CEL (95 integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra &raquo;</TD></TR><TR><TD CLASS="quote">Considering its a single wire connection, its either a bad connection or a bad vtec solenoid....sounds pretty easy to trace down.</TD></TR></TABLE>
two wire conection..and 21 is the oil pressure swith, 22 is the actual solenoid
Old Dec 20, 2006 | 08:48 PM
95 integra's Avatar
https://honda-tech.com/zerothread?id=978933
21 VTEC spool solenoid valve
22 VTEC pressure valve
Double checked it in my manual and it shows the same, code 22 is the oil pressure switch and 21 is the actual vtec spool.
Old Dec 21, 2006 | 06:17 AM
Boots's Avatar
oh well...i reset the ecu and it hasnt come back on yet so i know the solenoid's not bad...i hate the way my car runs in the winter
Old Dec 21, 2006 | 08:29 AM
95 integra's Avatar
Looks like a wiring grimlin then....or maybe you got mixed up on the code?
Old Dec 21, 2006 | 03:14 PM
Boots's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra &raquo;</TD></TR><TR><TD CLASS="quote">Looks like a wiring grimlin then....or maybe you got mixed up on the code?</TD></TR></TABLE>
yea im thinking its the wiring...im going to go back and solder all the connections and put new ecu pins in it...and im thinking because its so random it is wiring
obuhmyuh
Feb 26, 2008 10:07 AM
silverboost
11
Jul 11, 2006 04:46 AM
Bump
Sep 28, 2005 04:12 PM
Bimmerman
Jun 15, 2005 05:23 PM
VTC_CiViC
Nov 17, 2004 09:05 PM
