Integra smokin from engine!!??
Old Jun 28, 2005 | 10:08 AM
escape2me's Avatar
Default Integra smokin from engine!!??
So i was revvin my engine today with the hood open usin the throttle... I was holdin like 4 or 5 thousand rpm to investigate a stranged squeek that was happening ONLY at precisely 3500 rpm and then smoke was comin from my oil dipstick!! So i pulled it out and then it kept comin out of the little dipstick hole...WTF!? Also what the hell could be makin a squeekin noise at only 3500 rpm? Later today it changed from 3500 to somewhere like 5000 rpm.... WTF?
Old Jun 28, 2005 | 10:43 AM
escape2me's Avatar
Default Re: Integra smokin from engine!!?? (97 GSR)
Old Jun 28, 2005 | 11:34 AM
escape2me's Avatar
bump
Old Jun 28, 2005 | 11:38 AM
gsr_to_the_MAX's Avatar
mods?
color of smoke?
Old Jun 28, 2005 | 11:54 AM
escape2me's Avatar
Default Re: Integra smokin from engine!!?? (gsr_to_the_MAX)
All i have is an SRI and the smoke was like white
Old Jun 28, 2005 | 11:58 AM
SuzukaBlueAP2's Avatar
How was the oil level? Are you running low on oil in between oil changes? Are there any leaks after parking your car somwhere overnight?
Old Jun 28, 2005 | 12:03 PM
escape2me's Avatar
Default Re: Integra smokin from engine!!?? (ScreaminTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScreaminTeg &raquo;</TD></TR><TR><TD CLASS="quote">How was the oil level? Are you running low on oil in between oil changes? Are there any leaks after parking your car somwhere overnight?</TD></TR></TABLE>Yeah a couple times i noticed i was low on oil between changes... for the most part its got plenty of oil most of the time...
Old Jun 28, 2005 | 12:08 PM
dont know if this is related to your prob at all but how is your compression?
Old Jun 28, 2005 | 12:14 PM
escape2me's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr_to_the_MAX &raquo;</TD></TR><TR><TD CLASS="quote">dont know if this is related to your prob at all but how is your compression?</TD></TR></TABLE>I dont know... but im gonna be boostin soon so i want my **** to be runnin good you know...
Old Jun 28, 2005 | 12:39 PM
PURPLETERROR aka BIGMATT's Avatar
Do a compression test, that smoke you are describing sounds like extreme blowby, from bad rings/cracked ringlands. As far as the squeek goes, it could be the alternator bearing, dizzy bearing, ps pump, or ac clutch. remve your belts and turn each one by hand and check for any play, or roughness.
Old Jun 28, 2005 | 12:46 PM
escape2me's Avatar
Default Re: Integra smokin from engine!!?? (PURPLETERROR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PURPLETERROR &raquo;</TD></TR><TR><TD CLASS="quote">Do a compression test, that smoke you are describing sounds like extreme blowby, from bad rings/cracked ringlands. As far as the squeek goes, it could be the alternator bearing, dizzy bearing, ps pump, or ac clutch. remve your belts and turn each one by hand and check for any play, or roughness.</TD></TR></TABLE> Uh waht teh hell does taht mean? Is it real bad or what?
Old Jun 28, 2005 | 01:09 PM
it means you compressed air and fuel is making its way past the rings and into you crankcase, thats why you are seing smoke comming out your dipstick tube
Old Jun 28, 2005 | 01:11 PM
escape2me's Avatar
Damn... How much to fix it?? Also what could have caused it? I mean i take care of my car...
Old Jun 28, 2005 | 01:27 PM
Racermech's Avatar
This could be wrong, but i have heard of the dip stick tube comming loose, or falling out all togher. It could be loose and dripping some oil and burining off.
Search in the ITR forum, there is a 4 or 5 page thread about the dip stick coming loose
Old Jun 28, 2005 | 01:59 PM
escape2me's Avatar
Default Re: Integra smokin from engine!!?? (Racermech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Racermech &raquo;</TD></TR><TR><TD CLASS="quote">This could be wrong, but i have heard of the dip stick tube comming loose, or falling out all togher. It could be loose and dripping some oil and burining off.
Search in the ITR forum, there is a 4 or 5 page thread about the dip stick coming loose</TD></TR></TABLE>thanks
Old Jun 28, 2005 | 06:38 PM
escape2me's Avatar
apparently im gettin some blow by... what the hell is that? And how bad is it? easily fixed?
Old Jun 28, 2005 | 06:43 PM
Absubtle's Avatar
How many miles you have on the engine? And is your car ever overheating? Too many variable to diagnose. AND at that an internet diagnoses.
Absubtle
PA
Old Jun 28, 2005 | 06:51 PM
escape2me's Avatar
Default Re: (Absubtle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Absubtle &raquo;</TD></TR><TR><TD CLASS="quote">How many miles you have on the engine? And is your car ever overheating? Too many variable to diagnose. AND at that an internet diagnoses.
Absubtle
PA</TD></TR></TABLE>thats the thing, its a very well treated 70K b18... I hadnt driven the car in about a week before this happened btw... im hopin it was just a little residue gettin heated up and burnin on the exh manifold or somethin, a leak..
Old Jun 28, 2005 | 07:00 PM
apok's Avatar
Default Re: (97 GSR)
If it was coming out of the dipstick tube, you have air and fuel below the compression rings in at least one cylinder. Might as well install new rings at this point, though, since you are going turbo. If you install new rings, it will most probably go away. Right now you are losing compression, though, so don't race or rev your car. It is only detremental to the health of your engine at this point.
Old Jun 28, 2005 | 07:03 PM
escape2me's Avatar
Default Re: (apok)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by apok &raquo;</TD></TR><TR><TD CLASS="quote">If it was coming out of the dipstick tube, you have air and fuel below the compression rings in at least one cylinder. Might as well install new rings at this point, though, since you are going turbo. If you install new rings, it will most probably go away. Right now you are losing compression, though, so don't race or rev your car. It is only detremental to the health of your engine at this point.</TD></TR></TABLE>Thanks man, is there anyway to test this theory for sure... oh and ha ha im actually goin blower....
Old Jun 29, 2005 | 08:20 AM
escape2me's Avatar
Will a compression test determine whether or not i have a blow by problem..
Old Jul 2, 2005 | 10:24 AM
mpham529's Avatar
white smoke is usually a coolant leak.
Jeruvke
Mar 20, 2019 12:04 PM
BoltonGSR
Jun 25, 2007 07:47 AM
wessieball
Jul 6, 2006 04:15 PM
88crxhfb16
Oct 2, 2005 12:41 PM
SantaCruz92Si
Apr 29, 2005 10:16 AM
