Integra sitting for 3 month problem
Old Jan 16, 2004 | 09:45 PM
KW2000's Avatar
Default Integra sitting for 3 month problem
car starts just fine...but the car will not go into gear at all...tryied heating up car still nothing?? any ideas
Old Jan 16, 2004 | 09:59 PM
thaiphob's Avatar
Nikon!!!
Default Re: Integra sitting for 3 month problem (KW93LUDE)
does the car go into gear when the car is not on?
have your checked your tranny fluid?
Old Jan 16, 2004 | 10:00 PM
J337_UNIT's Avatar
Clutch fluid?
Old Jan 16, 2004 | 10:17 PM
KW2000's Avatar
Default Re: Integra sitting for 3 month problem (thaiphob)
yes, the car does goes into gear when not started
i havnt checked the fluid yet, is there a resivour where i could check it? or do i have to pull the bolt to check the level becuz i know on automatics its ez to check the fluid
Old Jan 16, 2004 | 10:57 PM
TeGGY_LS's Avatar
one of my bois had the same problem but it was wid a dsm.....we tried bleeding his clutch master cylinder but didnt work......so now we think its either the throw off bearings or a bad clutch master cylinder all together.......we are still trying to figure out wat it is....iono if that helped any
Old Jan 16, 2004 | 11:00 PM
veggiemaster's Avatar
Default Re: Integra sitting for 3 month problem (TeGGY_LS)
have you checked the clutch cable? my cable slipped and basically kept the clutch engaged the whole time even though it felt like the pedal was working fine.
Old Jan 16, 2004 | 11:05 PM
KW2000's Avatar
Default Re: Integra sitting for 3 month problem (veggiemaster)
well given that the car goes into gear when its not on..and it will go but when u bring it outa first it just locks up again i dont think its a shift linkage problem..we are gunna change the tranny fluid tomorrow and see what that will do...if theres still a problem then i dunno......he is military and is only home for 10 days..so maybe we'll get his car into honda..he is gunna sell anyways so..yea...
jwshilli
Jul 14, 2009 03:02 PM
scrEaMO Kyle
Nov 3, 2005 11:49 AM
vti444
Jun 13, 2005 03:44 PM
40oztoFreedom
Jun 3, 2004 11:40 AM
VTechie
Jul 12, 2002 04:09 AM
