integra problem
Old Dec 18, 2004 | 02:28 PM
b18c1acura's Avatar
Default integra problem
I own a 99 gsr that burns quite a bit of oil and I was curious what else besides worn out rings would cause this problem? My car has 87,000 miles and has aem intake w/ filter, skunk 2 intake manifold, dc sports header, jg edelbrock throttle body and aem fuel rail. Everything inside the engine itself is stock w/ original miles. Hope this enough info! Please, any help on this would be great.
Old Dec 18, 2004 | 02:32 PM
G-bonic's Avatar
Hijacked
Default Re: integra problem (b18c1acura)
why did u post twice ?? didnt u get enough answer on the 1st one ???
Old Dec 18, 2004 | 05:04 PM
chrisnova's Avatar
Well, check your valves. Check out the manual for a compression test and it will help you to identify where the problem is. I would think it is the valves if you are certain the rings are tight.
Old Dec 19, 2004 | 09:23 PM
gsrlkn412s's Avatar
bad valve seals. they are notorious for going bad in b series heads
974drgs
May 2, 2011 01:47 PM
Boosteddb8
Sep 12, 2008 10:50 AM
typesguy
Aug 19, 2004 07:14 AM
EG6 SiR
Aug 4, 2004 07:50 PM
G U E C O
Jun 22, 2004 11:04 AM
