Integra Header Differences??
Old Jan 28, 2005 | 01:43 PM
90crxsib16's Avatar
Default Integra Header Differences??
I see 3 different headers for integras and they are for:
1) 90-91
2) 92-93
3) 94-01
Can anyone tell me the difference between the three? Is it length? O2 location?
Old Jan 28, 2005 | 02:04 PM
purplegsr's Avatar
Default Re: Integra Header Differences?? (90crxsib16)
90-91 have o2 in a different location, it's not at the collector as I recall and they are a slightly different length than the 92-93 integras. The catalytic converter is also a different length between 90-91 and 92-93.
As for 94-01, there are a lot of different sizes
94-01 LS has 1 o2 on the header collector
94-99 GSR has no o2 on the collector
00-01 GSR has 1 o2 on the header collector and is the same length as the 94-01 LS.
97-98, 00-01 ITR also has 1 o2 on the collector and is same as the 94-01 LS.
The 94-99 gsr header is usually mated with a 14 inch cat with either 1 or 2 o2s in the cat, depending on 94-95 or 96-99. Obd1 v. obd2.
All of the b-series headers will bolt up to the head, its just a length issue after that, at least with the OEM stuff. If you get into putting a JDM ITR 4-1 header on a 92 DA, you will run into other problems with crossmember clearance and possible oil pan issues.
Old Jan 28, 2005 | 02:12 PM
90crxsib16's Avatar
Default Re: Integra Header Differences?? (purplegsr (Exospeed))
Hey thanks for the info! That was quick!!
Old Jan 28, 2005 | 02:14 PM
purplegsr's Avatar
no problem, it's one of those useless pieces of information floating around in my brain.
Old Jan 28, 2005 | 02:20 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purplegsr (Exospeed) &raquo;</TD></TR><TR><TD CLASS="quote">The 94-99 gsr header is usually mated with a 14 inch cat</TD></TR></TABLE>
Have you confirmed that the length of the '94-'99 GS-R cat is indeed approximately 14 inches? I was under the impression that, since the stock '94-'99 GS-R manifold is around 4" shorter than the LS/ITR/'00+ GS-R unit, and the stock '94-'99 GS-R exhaust is roughly 4" longer, that the cat length is basically the same for all G3 Integra models. To the best of my knowledge, the only time a shorter cat was needed was when a longer "JDM" header was used with the stock-length '94-'99 GS-R exhaust. I could be mistaken, since I have no personal experience with the GS-R exhaust system, but that's the information I recall reading.
Old Jan 28, 2005 | 02:27 PM
purplegsr's Avatar
Default Re: Integra Header Differences?? (Padawan)
I have not confirmed the 14 inch cat on the 94-99 GSR, it is the only one I don't know, because I have owned a 00 GSR and a 92 LS and know that those 2 are very similar in length.
The people I know with a 95 and 99 GSRs both have test pipes, and their test pipes are significantly shorter than my cat, so I am inclined to believe the info I have heard about the 94-99 gsr cat being shorter than the others, but it could be due to using different length exhaust and JDM 4-1 header, etc. Mismatching parts on 10 year old cars is always a problem, I need to find a bone stock, smog legal 95 gsr and roll under it with a tape measure.
7mile
Sep 14, 2009 01:33 AM
Karterguy13
Jan 29, 2005 01:31 PM
phivelug
Jan 20, 2005 11:27 AM
blueintegra90
Sep 5, 2003 07:18 AM
h45454
May 12, 2003 02:47 PM
