Integra fuel injectors not firing
I have a built b18b motor in a 1998 Integra gsr. The problem I知 having is that I replaced the throttle body gasket and the TPS sensor (yes u calibrated it) and I went to crank and there was no start. I have made sure the tps works. My mai relay works as well I have tested it with a multi meter (both relays). I have power to the injectors 12v. I also have a brand new fuel pump and it痴 priming (340 LPH) it seems that everything is good but the injectors are not opening. I plan to use the multimeter to check the grounds on the ecu. I also am running Hondata and COP kit. I have checked for spark on the plugs and they池e running strong but my plugs are super dry as well. Car only starts with starting fluid.
Re: Integra fuel injectors not firing
Are you saying the new built engine ran fine BEFORE you changed out the throttle body gasket and TPS sensor ?
