installing a used motor
Old May 10, 2004 | 10:47 PM
253EK's Avatar
Default ? when installing a used motor
im installing a 1998 gsr motor shortly with less than 60,000 miles. i wanted to what parts i should/need to replace before swapping it in? timing belt, water pump, gaskets, etc?
since my cars a 94 obd1, whats do i need to make it work? i was told to get a jumper harness so i could use the obd2 dizzy, injectors and alternator.
i need my car running asap
HELP
thanks
Old May 11, 2004 | 04:23 AM
WreckedTeggie's Avatar
Default Re: ? when installing a used motor (253EK)
When i did my swap i changed spark plugs, ddist. wires, belts, all fluids.... it was obd1 to obd1 though so as for the injectors etc im not sure
Old May 11, 2004 | 06:22 AM
xSCTYGx's Avatar
Default Re: ? when installing a used motor (WreckedTeggie)
Get yourself an 0bd1 to 0bd2 conversion harness...but I would go ahead and change the timing belt and water pump, just because its much easier changing it when the motor is out of the car...and the fact that if it hasn't been changed, you'll need to changed it in about 20k miles anyway so get that outta the way. I would also change your alternator belt, wires, spark plugs, all your fluids, distributor, cap, and rotor.
Old May 11, 2004 | 07:22 AM
andera's Avatar
Default Re: ? when installing a used motor (xDA9x)
i thought and OBDII engine could run OBD1, you just don't utilize the other sensors...?
Old May 11, 2004 | 07:38 AM
Sack Master's Avatar
Default Re: ? when installing a used motor (andera)
Run obd-1 everything. There are a couple sensors you won't need. As for dist. Go buy an obd-1 dist. Obd-1 injectors. I don't know why people would even consider using obd-2 wiring, when the car is already setup for obd-1. Just run whatever wires to whatever sensors you need. If your car is a gsr, then you really won't need anything. If it's an ls, then you'll have to run some wires.
Old May 11, 2004 | 10:41 AM
roadrunner's Avatar
...can't he just use the OBD1 distributor and injectors from his old engine?
Old May 11, 2004 | 04:27 PM
253EK's Avatar
Default Re: (roadrunner)
thanks guys
but im still confused, everyone is telling me diffrent things, even shops around seattle. i was told to just run obd2....but from researching obd1 is the best bet.
what do i need?
TTT
Old May 11, 2004 | 11:12 PM
Default Re: (253EK)
Better question is what do you have left over from your obd-1 motor? Take your obd-1 wiring harness and plug it into your obd-2 motor. You'll need the obd-1 dist, and injectors and maybe have to swap some sensors becuase they don't plug in right(don't quote me on that though).
Old May 11, 2004 | 11:33 PM
deepgreengsr's Avatar
Default Re: (Sack Master)
ya sack master is correct, dont mess around with it, swapping harnesses is pretty straight forward. obd 1 engine bay. should stay obd1. I put a obd1 motor in my obd2 bay. keep them together. just swap injectors. and dizzy and a few other things. re wire the CAS to.
Old May 11, 2004 | 11:52 PM
gundamgsr's Avatar
obd1 motors accept mods better. try and find an obd2 ecu chip.
4dr_eg
18
Oct 28, 2013 04:26 PM
HXbandit
Mar 8, 2008 06:06 PM
fbmbmx
Oct 16, 2006 05:12 PM
D124gOn
Mar 4, 2003 07:20 PM
quikrpm'z
Feb 19, 2003 03:14 AM
