installing MSD cap and external coil
Old Mar 16, 2003 | 03:09 AM
JeremyL's Avatar
Default installing MSD cap and external coil
i was thinking of getting one of those MSD caps that allow for an external coil and was wondering where the external coil gets its power from?
Old Mar 16, 2003 | 04:29 AM
Xsi's Avatar
Xsi
Default Re: installing MSD cap and external coil (JeremyL)
You just extend the wires : http://www.geocities.com/wyvnz/MSD.html
Old Mar 16, 2003 | 06:27 AM
jdmhondaman's Avatar
If you are going to install yourself, make sure that you install everything at the same time. There was a guy who installed just the cap, thinking they were pretty much the same thing, and ended up ruining the cap and the stock coil. The power was arcing through the silicone that was there to house the tip of the stock coil and that is what burned. Just make sure that you take the whole distributor out of the car so you can get all the wiring done right and soldered, as well as take the stock coil out. That way, you will do everything right on the first try and it will look cleanly and professionally done.
Old Mar 16, 2003 | 09:41 AM
Acura_I-RS's Avatar
Default Re: installing MSD cap and external coil (jdmhondaman)
you dont have to take out the whole distributer, unless you want a big pain in the *** job, just extend the wires that went to the internal coil, out to whereever you mount the external coil, simple as that!
Old Mar 16, 2003 | 01:29 PM
ernald711's Avatar
i got the whole thing done and it still fukk'd up my distributor... i was using the msd sci with blaster ss coils...i had the get a new one and the the coil isn't even attatched anymore... fukk'n sucks
[Modified by ernald711, 2:31 PM 3/16/2003]
Old Mar 17, 2003 | 03:31 AM
JeremyL's Avatar
Default Re: installing MSD cap and external coil (ernald711)
so i cant just pop on the MSD cap and hook up the external coil via a wire?
Old Mar 17, 2003 | 04:38 AM
Xsi's Avatar
Xsi
Yep, just attach the coil via the coil wire to your MSD cap and extend the + wire from where it was on the stock coil to the + on your new coil. Do the same for the -ve.
dmossdrum91
Sep 8, 2015 02:44 PM
Junaid K
Mar 22, 2014 10:26 PM
SpoolnByYou
Mar 25, 2006 09:10 AM
xci_ed6
Oct 14, 2003 08:42 AM
