Installing Flywheel????difficult?
Old Mar 21, 2003 | 09:17 AM
AK94GSR's Avatar
Default Installing Flywheel????difficult?
I will be switching out my tranny soon and want to install a lightened flywheel at the same time. Is the installation process hard so long as you make sure everything is torqued down correctly???
is there anything i should look out for or any tips people have to offer??
Old Mar 21, 2003 | 09:29 AM
Eva01's Avatar
Default Re: Installing Flywheel????difficult? (AK94GSR)
Hard part is dropping the tranny. After the tranny is out of the way,you pretty much just unbolt the old flywheel and bolt up the new one. There is a certain pattern that you must torque down to bolts but other than that...simple. Also, you may want to use locktite on the bolts to prevent them from backing out, you will need 17mm 12pt socket and 76ft/lbs is the torque specs for the flywheel bolts. HTH
Edit: Whoops should be 17mm 12pt socket not 12mm. Sorry.
[Modified by Eva01, 9:26 PM 3/21/2003]
Old Mar 21, 2003 | 10:26 AM
AK94GSR's Avatar
Default Re: Installing Flywheel????difficult? (Eva01)
Yeah i got a helms, but just wanted to see if anyone had anytips for me to ease my installation.
if anyone else has any please let me know
thanks Eva01
Old Mar 21, 2003 | 10:27 AM
tilt's Avatar
https://honda-tech.com/zerothread?id=450035
Old Mar 21, 2003 | 01:10 PM
AK94CIVICGRL's Avatar
Default Re: Installing Flywheel????difficult? (tilt)
Hey thanks
ramboPandA
May 4, 2016 09:54 PM
regal1975
Dec 2, 2007 02:17 PM
dat_flip
Sep 4, 2004 05:25 PM
Soccerking3000
18
Jan 6, 2004 08:17 PM
hybridb18
Dec 14, 2002 04:49 PM
