installin a ls head
Old Dec 27, 2008 | 07:54 PM
TURBO+GSR+CRX=?'s Avatar
Default installin a ls head
i have an acura and i had a blown head gasket and some stuff.. i bought another head and im going to put it on how do i remove and put the other the one including timing and valve adjustment i was told i can do like this..
remove the head .. before putting on the new head set the piston 1 to top dead center then drop the new head in set the cams with the arrow pointing 12 o clock.. and thats it right..
Old Dec 27, 2008 | 08:52 PM
mouab18c1's Avatar
Default Re: installin a ls head
get a Haynes book or a Chilton book for guidance if you havent done it before....its simple but time consuming...you will need sockets size of 10mm 12mm 14mm..forgot what size it is for the headstuds...and a breaker bar...mans best friend unless you have power tools...
first let your car cool down...then drain your coolant and oil..disconnect your battery... disconnect all connecters at the head and IM..take off your headers...power steering and ac if you have it.break loose your crank pulley bolt..then take off your valve cover...remove your intake...and then your distributor....once VC is off take off cam covers...with book guidance make sure you take them off in the right order...once that is off take off your crank pulley and timing belt covers...loosen your belt tensioner bolt size 14..that should loosen up the tbelt which it should be kind of loose after taking your cam covers off....slide belt off cam gears...cams should pull right off....then loosen your headstuds and pull off your head..
when installing make sure you resurface your new head....get a new hg and new headstuds..and maybe new IM gasket if you have to transfer your old one onto your new head...then put everything back on...make sure your hg is in right...slap your head back on...and put everything back on....torque head bolts in the correct pattern and to torque specs..also when doing with cam caps...set your block to tdc and cam gears with both arrows saying UP to 12 oclock....and make sure you do put on your timing belt correctly....along with everything else you took off..hope this helps...long story short just for you...LOL
Old Dec 27, 2008 | 08:53 PM
mouab18c1's Avatar
and for valve adjustment you will need a special tool for that....
Old Dec 27, 2008 | 09:20 PM
do i really need to do the valve adjustment.. to put on the new head or can i just toss on the head and it will still run ... right..
Old Dec 28, 2008 | 04:25 AM
1SicLS's Avatar
i would. is it a used head or brand new?
Old Dec 28, 2008 | 04:34 AM
IN VTEC's Avatar
I do all of my valve lashing with just a ratchet, feeler gauges, and a screwdriver.
Old Dec 28, 2008 | 09:42 AM
mouab18c1's Avatar
not necessary but you can....
Old Dec 28, 2008 | 05:46 PM
ok thanks for info but...
i am using everything from this head except the valves and putting it on the other head.. the head i bought is used and just has the valves on it is it hard to transfer everything on my head to the new one..
Old Dec 29, 2008 | 12:15 AM
Jimmy's Avatar
Global Moderator
basically everything he said
I just had to install an LS head on my b20b bottom end.. I used OEM honda headgasket.. i had read mixed reviews about felpro gaskets.. so i was fixing to boost the car so i didn't wanna take a chance. If you have to swap the intake manifolds over be sure to replace the gasket..
You don't haft to completely remove the exhaust manifold just unbolt it from the head and slide it down out of the way.. On the cam caps be sure to remove them in order and the arrow on the faces the cam gear.. on the cam caps on the ends put a little gasket maker around the area.. (you will see in illustrations)
I highly suggest you make sure you have a manual if you've never did it before.. google the term ''hondahookups manual'' and find the specific manual for your car. It also has the torque specifications for the head bolts and cam caps.. basically everything and anything you could want to know about your engine.
Old Dec 29, 2008 | 08:18 AM
mouab18c1's Avatar
so your going to transfer the rocker arms from your old head to your new head? i myself have never done it before but i highly recommend you take it to shop to do it if your effy about it....
Old Dec 29, 2008 | 08:20 AM
mouab18c1's Avatar
or again just get a manual book and refer to it....
Old Dec 29, 2008 | 08:37 AM
seanbev24's Avatar
Be careful swapping worn parts between used heads as things wear differently. Also, make sure you stay organized and keep parts in the original order in which they were removed.
yblegal
Dec 1, 2010 09:53 AM
bmg123
Feb 7, 2010 07:20 AM
Turbo_y8
Jan 29, 2006 08:27 PM
domestic_rice
Sep 25, 2005 12:49 PM
QCKGSR
Apr 14, 2003 06:49 PM
