injector sizing?
Old Nov 2, 2004 | 04:03 PM
integraLS-T's Avatar
Default injector sizing?
I built a custom turbo kit using a mitsu 14b turbo. What size injectors will i need to make sure i dont run lean. Im planning to use a s-afc 2 for management with a wideband for fine tunning. . And the boost is going to be set somewhere around 8psi. Thanks for the help.
Old Nov 3, 2004 | 03:22 PM
bitchin camaro's Avatar
Default Re: injector sizing? (integraLS-T)
One of my buddies is running a Full-Race T3T67 with 1000cc injectors...if that helps at all?
Old Nov 3, 2004 | 03:27 PM
virusiidx's Avatar
just get some dsm 440's for only 8psi. Don't plan to get the safc, its very limited. Get hondata or uberdata for better tuning.
Old Nov 3, 2004 | 03:31 PM
B18OnTop's Avatar
Default Re: (virusiidx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by virusiidx &raquo;</TD></TR><TR><TD CLASS="quote">just get some dsm 440's for only 8psi. Don't plan to get the safc, its very limited. Get hondata or uberdata for better tuning.</TD></TR></TABLE>
Old Nov 3, 2004 | 10:13 PM
Electron_LS-Vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integraLS-T &raquo;</TD></TR><TR><TD CLASS="quote">I built a custom turbo kit using a mitsu 14b turbo. What size injectors will i need to make sure i dont run lean. Im planning to use a s-afc 2 for management with a wideband for fine tunning. . And the boost is going to be set somewhere around 8psi. Thanks for the help.</TD></TR></TABLE>
Rule of Thumb......take the volume the injectors put out and make it horsepower... I.E. 550 CC injectors should be able to support 550 horsepower... but i would be generous with the numbers just to be sure...you shouldnt need anything over 400....
BI8B
Jan 6, 2005 05:33 AM
BoostedJeff
Dec 12, 2004 09:36 PM
frostcivic
Aug 6, 2004 02:22 PM
Kp_VtekNiks
Dec 18, 2003 07:02 AM
gsrhatch530
Dec 16, 2003 03:48 PM
