Most WHP on DSM 450s
Re: Most WHP on DSM 450s (1 Cam Wonder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 Cam Wonder »</TD></TR><TR><TD CLASS="quote">wouldnt mind knwoing what PSI they can hold either</TD></TR></TABLE>
that all depends on turbo size, you cant really determine this factor, better measured with whp
Re: Most WHP on DSM 450s (JRciv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JRciv »</TD></TR><TR><TD CLASS="quote">Hope you like math.
http://www.rceng.com/technical.htm</TD></TR></TABLE>
....**** that.
....**** that.
Guest
Posts: n/a
Re: Most WHP on DSM 450s (BoostedJeff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedJeff »</TD></TR><TR><TD CLASS="quote">
....**** that. </TD></TR></TABLE>
just get brian to do the math .... he knows that ****
According to RC's calculator, assuming 60 psi, .57 BSFC (mine's supercharged), 85% duty cycle, I could support 250 WHP (295 crank horsepower) with my 450s.
Re: Most WHP on DSM 450s (Jaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jaker »</TD></TR><TR><TD CLASS="quote">According to RC's calculator, assuming 60 psi, .57 BSFC (mine's supercharged), 85% duty cycle, I could support 250 WHP (295 crank horsepower) with my 450s.
i def know they are good for more than that
most boosted cars i've seen, including my old setup, maxed those injectors out in the 260whp range with base fuel pressures under 50 psi. I would say stay under 250whp with them and make sure you have them cleaned and balanced before you do anything.
dsm 450cc... i would say are good to 400 whp ..
i ran for about 7 months dsm450's at 60 psi .. with 14-16 psi of boost and was making 310 whp ..... and 209 trq... BUBBA TUNNED
they do the job ...
they do the job ...
Location: Standing on the corner selling cocaine, rippin shows live on stage for hoes yellin my name
Re: Most WHP on DSM 450s (havok hybrid)
My buddy maxed his out on his GST at a little over 300whp. He also had his car tuned and upgraded with a Holley fuel pump on a 16G turbo setup. 450cc injectors aren't gonna make more than 350whp.
Re: Most WHP on DSM 450s (JDMThoughts)
It also depends if you are running a fmu or something like a hondata. With a fmu and crazy high (100+psi) fuel pressure I could see making 330whp+. But running a safe setup without maxing out the injectors I would think 300whp would be about it.
Re: Most WHP on DSM 450s (hybrid901)
DSM 450cc injectors
@ 120% duty cycle, I think
346whp / 263tq @ 10psi
https://honda-tech.com/zerothread?id=1004041
Good link . Looks like I'll be buying some 750's
Phil
Phil
Location: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Re: Most WHP on DSM 450s (beerbongskickass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beerbongskickass »</TD></TR><TR><TD CLASS="quote">DSM 450cc injectors
https://honda-tech.com/zerothread?id=1004041</TD></TR></TABLE>
Damn, looks like DSM 450's will work fine for my goals!
Do you know what 120% duty cycle means? Thats not physically possible. 100% duty cycle means they are open ALL the time. Anything over 100% duty cycle, and there's not a drop of extra fuel over 100% duty cycle.
Do you know what 120% duty cycle means? Thats not physically possible. 100% duty cycle means they are open ALL the time. Anything over 100% duty cycle, and there's not a drop of extra fuel over 100% duty cycle.</TD></TR></TABLE>
i be using my m4d tyte injectors at 250% doodie cycle, yO
i think what beerbongs meant was that according to uberdata calculations on the injector duty tab is that at XXXWHP it was XXXduty cycle, which i think everyone has already come to the conclusion that the injector duty tab on Uber may be off.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jaker »</TD></TR><TR><TD CLASS="quote">Do you know what 120% duty cycle means? Thats not physically possible. 100% duty cycle means they are open ALL the time. Anything over 100% duty cycle, and there's not a drop of extra fuel over 100% duty cycle.</TD></TR></TABLE>
Yeah pretty much like evosol was saying, uberdata just said 120%. My buddy was sitting there tuning the car and it needed more fuel so he wondered what would happen if he set the duty cycle to 120% lol. Hell I think it might have been even higher. I also noticed when getting my car tuned duty cycle was pretty high, but I was only making like 215whp, so my injectors had a lot more to go. Give me a break I only had a few hours sleep when I posted that last night.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedJeff »</TD></TR><TR><TD CLASS="quote">doodie cycle, yO</TD></TR></TABLE>
haha, you said doodie.
boostincoupe
Sory but dsm injectors is kind of a gheto way of doing things. They are low impedance which means you will need a resister box. go with some high impiedant 440cc, or some 500cc that bolt right in. Oh another thing never lissen to boostincoupe he is a dumb ***....
