Injector question
Old Aug 8, 2011 | 06:24 PM
Zac W.'s Avatar
Default Injector question
Bought a 96 b18b1 motor to put back in my 99 LS. Then bought a 96 LS wire harness. Here's the problem...injectors won't plug into plugs. So either the wire harness or motor isn't obd2 which is what I'm after. So how can u tell which harness I have?? The plugs are black on harness. The ones that came with injector were grey but the retard just cut the wires. Or can I just cut off the plugs I need and match the colored wires together? I would rather just find different injectors that will match up to my harness.
Old Aug 9, 2011 | 09:04 AM
1ls/vtec's Avatar
Default Re: Injector question
you can cut the wires and put the ones on that u need, that'll work fine or u can alter the plugs. Mine had a notch in them that wouldnt allow my injectors to plug in so I just filed it down and they worked.
Old Aug 9, 2011 | 08:30 PM
Zac W.'s Avatar
just read that in an old thread! thanks tho!
skoodles2k6
Apr 26, 2012 03:52 PM
95JDM
Mar 7, 2008 12:52 PM
silentdaredevil2
Welding / Fabrication
Jan 19, 2006 05:52 PM
KustomCrx
Oct 10, 2004 01:23 PM
