Injector Problems?
Old Aug 31, 2009 | 07:02 PM
jdmboy94's Avatar
Default Injector Problems?
well i just swapped a b20b in to my integra. i had a built ls and i pulled it out. well i put stock injectors back in it and it wouldnt fire up. its getting gas to the fuel rail, but not comming out the injectors. so i put the 450cc injectors that i had in the old motor, to see if i just had bad injectors, well they worked fine and the car fired up. so long story short i tried 2 more sets of injectors and neither of them worked? so im stumped?any ideas
Old Aug 31, 2009 | 07:08 PM
jdm602's Avatar
Default Re: Injector Problems?
you need to get a stock b20 map for; im guessing the chipped ecu your running.
basically your trying to run the built ls with 450's tune on the stock b20 with 240cc injectors. it just wont run right.
Old Aug 31, 2009 | 07:20 PM
jdmboy94's Avatar
sorry i forgot to put that in the orginal post,i have a stock b20 ecu on the car now. the chipped ecu is out
Old Aug 31, 2009 | 07:47 PM
jdm602's Avatar
did you use resistors for the 450 injectors? also what ecu is it? and what year integra?
Old Sep 1, 2009 | 02:48 AM
jdmboy94's Avatar
yea i used a resistor box for the 450s, but i took it off when i went back stock. i think its a p75 but i have to look, i cant remember if i changed it out, its a 94 integra
Old Sep 1, 2009 | 01:45 PM
jdmboy94's Avatar
anybody?
Fnix
May 17, 2012 03:04 PM
gonmaro
Apr 1, 2009 07:14 PM
top end tuner
Sep 24, 2007 08:41 PM
EKHWhat
Feb 2, 2007 05:38 PM
Kaiahua
Jan 10, 2007 07:52 AM
