injector change
Old Feb 21, 2004 | 04:23 PM
chaps7931's Avatar
Default injector change
i want to change the injectors from my 2000 integra ls, i want to know what would be the best injectors for it. i also had a question because my friend had told me to replace them with those of an eclipse, if this is something i should do and if so what else do i have to change. like the fuel rail
Old Feb 21, 2004 | 04:52 PM
MyBigNut's Avatar
Default Re: injector change (chaps7931)
Reason for change? Going turbo? Building motor?
Changing just the injectors won't do anything unless you got something else planned.
Give a little more info.
Old Feb 21, 2004 | 04:56 PM
NuclearB18B's Avatar
Default Re: injector change (MyBigNut)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MyBigNut &raquo;</TD></TR><TR><TD CLASS="quote">Reason for change? Going turbo? Building motor?
Give a little more info.</TD></TR></TABLE>
Old Feb 21, 2004 | 11:20 PM
Downey's Avatar
theres no point in changing them unless u have some type of vafc or hondata to controll it.
lets say the stock ecu runs the stock 240cc injectors at 80% duty cycle.. then what ever u replace them with will dump alot more fuel in and you will run really rich
only upgrade to bigger ones if your going s/, turbo or built na.
civic_jones
Sep 7, 2008 10:43 PM
hondadriver
Feb 16, 2005 06:38 PM
Bintegra
14
Jul 29, 2004 08:11 PM
chaps7931
Feb 21, 2004 06:54 PM
WONG FRIED RICE
Jul 15, 2003 10:52 AM
