improving mpg
Old Apr 23, 2008 | 06:26 PM
Shirozu's Avatar
Default improving mpg
hey guys, most of us know that gas prices are like through the roof right now. i am wondering in what ways can we improve our mpg. i've tried the usual tire air pressure, fuel filter, pcv valve, and new ngk spark plugs and wires. im thinking of upgrading the intake, exhaust, and header systems as well. do you guys know if these bolt-ons will increase mpg if you drive normally (not using a heavy foot)? im thinking of aem sri, apexi ws2, and skunk2 headers. are these good parts?
Old Apr 23, 2008 | 06:27 PM
Gunmetal Grey's Avatar
Default Re: improving mpg (Shirozu)
Consider driving at or under 70mph on the freeway, changine your primary O2 sensor, and buying lighter rims/tires.
Old Apr 23, 2008 | 07:35 PM
thestorysritehur's Avatar
the apexi ws2 is not a straight throw muffler so you wont see too much of a difference between stock and that, i would recommend greddy sp2, its just as quiet as the ws2, but it is straight through, and right now i put an AEM CAI and the sp2, and to be honest i havent seen too much of a MPG difference, maybe a little but nothing too significant
Old Apr 23, 2008 | 07:44 PM
teggsr925's Avatar
Default Re: improving mpg (Gunmetal Grey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gunmetal Grey &raquo;</TD></TR><TR><TD CLASS="quote">Consider driving at or under 70mph on the freeway, changine your primary O2 sensor, and buying lighter rims/tires. </TD></TR></TABLE>
just dont drive like an ***.
Old Apr 23, 2008 | 08:03 PM
vladd's Avatar
so you're going to spend all that money on i/h/e just to possibly get an extra 1-2 mpg (not even garaunteed)? is paying for the parts really going to be worth the miniscule amount of money you might possibly save on gas?
Old Apr 23, 2008 | 08:26 PM
ZE12O's Avatar
Default Re: improving mpg (vladd)
O2 sensor ftw
Old Apr 23, 2008 | 09:34 PM
SkaiWu's Avatar
he probably considered other things than just mpg =X
Old Apr 23, 2008 | 09:39 PM
vladd's Avatar
Default Re: improving mpg (SkaiWu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkaiWu &raquo;</TD></TR><TR><TD CLASS="quote">he probably considered other things than just mpg =X</TD></TR></TABLE>
the original post was about improving mpg, nothing else. i/h/e will cost much more than any amount of money you'll ever save on gas.
Old Apr 23, 2008 | 09:42 PM
TOO MUCH TORQUE's Avatar
shift from under 3.2k rpms, but over 2.7k. watch your throttle position.
Old Apr 23, 2008 | 10:03 PM
iwantturbo's Avatar
apexi ws2= $400
aem intake= 250
skunk2 headers= <U>+250 </U>
$900 in parts
depending on where you live, thats like filling up your gas like 30-38 times already. Just save your money by not buying parts and just using it to pay for gas.
Old Apr 23, 2008 | 10:08 PM
Rikter's Avatar
That's a lot of dough spent on parts to save a few cents at the pump (as explained by iwantturbo).
If you cannot afford gas, get a bus pass.
-Rik
Old Apr 23, 2008 | 10:24 PM
vladd's Avatar
Default Re: (Rikter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rikter &raquo;</TD></TR><TR><TD CLASS="quote">That's a lot of dough spent on parts to save a few cents at the pump (as explained by iwantturbo).
-Rik</TD></TR></TABLE>
the bus pass will be cheaper than the i/h/e.
Old Apr 24, 2008 | 04:46 AM
meet_friend_hk2's Avatar
Without a good tune, you will only see a huge drop in MPG because of running RICH....
Old Apr 24, 2008 | 07:40 AM
Shirozu's Avatar
Default Re: (meet_friend_hk2)
well actually it was only going to cost around ~$600 for the parts that i mentioned. again, improving mpg is my top priority goal (for the car) with a little spirited driving every now and then.
ive heard many things about the stock pieces being a bit restrictive which is why I thought that these bolt ons could let the engine flow a bit more freely meaning less throttle to achieve the desired speed and less gas used (improved mpg.)
then again i have a also heard that without a tune that this would actually reduce mpg. I guess what I am trying to say if it will actually reduce mpg (if even 1-2 mpg increase means at least 20 miles extra). I plan to keep the car for at least 5 more years so would this be a more viable option or just keep it stock?
Old Apr 24, 2008 | 09:50 AM
cheapskate's Avatar
Default Re: (Shirozu)
search HYPERMILING on google or you tube i just started doing it and i am anxious to see the results
Old Apr 24, 2008 | 07:43 PM
ThatGreenGsr's Avatar
do weight reduction on your car it can help some
Old Apr 24, 2008 | 08:03 PM
vladd's Avatar
[QUOTE=Shirozu]well actually it was only going to cost around ~$600 for the parts that i mentioned. again, improving mpg is my top priority goal (for the car) with a little spirited driving every now and then.
[QUOTE]
cutting out the 'sprited driving' will do more to increase your mileage than anything else. buying i/h/e will only make you want to do more of it.
noname87
Apr 25, 2012 11:18 AM
lax1089
Apr 4, 2007 09:27 PM
twounderstand
Honda Civic (2001 - 2005)
Aug 19, 2006 08:49 PM
srv3fender
Sep 16, 2004 09:35 PM
E46M3CB
Oct 24, 2003 09:51 PM
