I'm screwed
Old Jun 17, 2009 | 08:41 PM
volcom_7_1's Avatar
Default I'm screwed
My acura is shooting oil out of the block and when i try to startit my resevore coolant starts bubliung
Old Jun 17, 2009 | 08:43 PM
itslogz's Avatar
Default Re: I'm screwed
Yep you're screwed.
With that information given, thats all i'm going to say. Maybe some more info, maybe something related to the problem...
Old Jun 17, 2009 | 08:46 PM
volcom_7_1's Avatar
I dont know though. It was running fine and i had to pull the Valve cover on and aftert that when I shifted it would delay a lil and also before that I guesss the previous owner told me oil was allready getting to the plugs. Then today i was driving it and it started smoking and had no oil cause it was coming out the plugs then i put coolant in it also but every time i trried starting it it would shoot out or bubble. Ohh and it wont start now.
Old Jun 17, 2009 | 08:54 PM
mrdeadman's Avatar
They let me pick
https://honda-tech.com/forums/acura-integra-6/creating-new-topic-choose-subject-specific-title-not-help-me-asap-2477272/
Old Jun 17, 2009 | 10:50 PM
Capt. Jimbo McSubipants's Avatar
headgasket
did you replace it lately?
dont run it as you'll more then likely cause more damage
Old Jun 17, 2009 | 10:53 PM
volcom_7_1's Avatar
No well I noticed it was running weird and my friend douch bag drove it and dropped a gear till i stopped him and had my uncle tow it back. But oil is everywhere on it when i pull the plugs out its just drowning in it. Is that wh ythe coolant is bubling when i try to start it to you think?
Originally Posted by Capt. Jimbo McSubipants
headgasket
Old Jun 17, 2009 | 11:14 PM
if you want an internet opinion since i'm not there it sounds like you have a headgasket problem
headgaskets aren't the end of the world to change...so swap it out....flush your coolant system and change your oil and inspect what you can while the head is off
Old Jun 17, 2009 | 11:17 PM
volcom_7_1's Avatar
Thank you so much and yeah i know it isnt the end of the world lol but my car is my life lol and when it shoots oil outa spots its not suppose to be in lol I get worried
Old Jun 18, 2009 | 07:17 AM
pmey's Avatar
Not enough details
From what you're saying oil in spark plug that Valve cover gasket leaking to the spark plug can cause you to run on 3 cylinders. Mabe that why you're geting lag on lower rpm.
Water bubbling in you're reserve tank can be water pump too.
Is there oil in coolent, if you twist of the oil cap do you see any milky stuff on it?
if you do it's the Headgasket.
"So I say before you start anything do a Compression test and Leak down Test."
Old Jun 18, 2009 | 11:15 AM
volcom_7_1's Avatar
Well when I had it at my uncles it was empty on coolant. So we put some in it and every time I would try to start it water would just spit right back out... I havnt noticed any oil in the coolant cause all the coolant is just put in.
Originally Posted by pmey
Not enough details
Old Jun 18, 2009 | 11:23 AM
94 ls-r's Avatar
Sounds like the compression is leaking through head gasket and blowin out the water. Do a compression check. If a cylinder is low then it is the head gasket. As for oil in the plug holes it sounds like the spark plug tube seals ar leakin on valve cover.
Old Jun 18, 2009 | 11:27 AM
volcom_7_1's Avatar
Ok cool yeah I'm gonna gonna go to work on it this weekend and hopefully get it goin again. Thank you everyone for helping me out
Old Jun 18, 2009 | 04:09 PM
94 ls-r's Avatar
No prob. Let us know what goin on after ya work on it. Good luck!
Old Jun 18, 2009 | 04:18 PM
volcom_7_1's Avatar
Yeah thank and I might look around and see this as a chance to get a new head maybe.
Old Jun 18, 2009 | 05:06 PM
RA429's Avatar
if you took off the valve cover and starting leaking oil when you put it back on, it might be because you didnt replace the spark plug ring gaskets that set in the valve cover...
double check that before you go digging into the motor
Old Jun 19, 2009 | 10:08 AM
Green Teggy's Avatar
simply sounds like you didn't change the spark plug o rings when you had the valve cover off and a lot of oil leaked out and because not having any oil or coolant in your car you overheated it. Goodluck time for a head gasket
tobytigger
Sep 26, 2013 10:47 PM
Honda_Si21
12
Mar 27, 2011 08:40 PM
honda-freak
Apr 12, 2006 03:23 PM
boosted hybrid
Jul 9, 2003 07:43 PM
redteg1
Aug 27, 2002 10:39 AM
