Ignition replacement
Old Sep 26, 2006 | 02:10 PM
rehab_this's Avatar
Default Ignition replacement
Damn theives broke into my '92 integra! They tried to plunge into the ignition, but couldn't. I tried starting the car with my car keys, but the car keys won't turn in the ignition. My question is, how hard is it to replace the ignition? GOD DAMN THEIVES!!!
Modified by rehab_this at 5:31 PM 9/26/2006
Old Sep 26, 2006 | 07:01 PM
rehab_this's Avatar
Default Re: Ignition replacement (rehab_this)
anyone???
Old Sep 26, 2006 | 07:28 PM
Jose-aka-Pedro's Avatar
Its not too bad,
Go to your local Junkyard and find a G2 Integra. With the key in the ignition
or the key in the car that works in that ignition
Begin taking it apart and you'll be able to get it.
If you havnt ever taken it apart its not too hard.
Start with the steering wheel, the cover and then begin taking the ignition assembly out.
Only problem with this is you'll have a diffrent key for starting it.
Or you can pull the door lock and trunk lock and have the same key for everything.
Old Sep 26, 2006 | 07:59 PM
harrykong's Avatar
find one one ebay should be easier. There are 2 bolts that hold the ignition to the steering column. Get a dremel and make a large notch in them to place a screw driver in so they can be removed. once the bolts are off unplugged the 2 plugs from the igintion to your harness and your good. replace in reverse order
pepsi813
May 19, 2019 12:37 PM
dustinrathke24
Sep 14, 2018 01:00 PM
SavMac14
Apr 2, 2013 09:35 AM
phyzJunkieCivic
Mar 7, 2007 11:15 PM
wuhungsixxx
Apr 8, 2002 03:54 PM
