Ignition coil question
Old Jan 11, 2003 | 07:19 PM
DSayavan's Avatar
Default Ignition coil question
Recently my car takes a couple of extra cranks to start it up. Sometimes it will start and then die immediately. My starter sounds like its fine, its not making the infamous clicking sound that bad starters do. I swapped out my dist. cap & rotor, and still have the problem. I've noticed that it happens whenever the car has been running for a while, not on cold starts. My question is, could it be a bad ignition coil? What are the symptoms of a bad coil? Thanks in Advance.
Old Jan 11, 2003 | 08:43 PM
97hb's Avatar
Default Re: Ignition coil question (DSayavan)
Check the main relay. Usually the coil is either good or bad. If it is the coil then it is the contacts of the coil that are corroded.
nanagsr
Jun 24, 2009 07:04 PM
Markis.
Nov 14, 2006 05:27 AM
redintegra1998
Aug 1, 2005 05:30 PM
