ignition coil?
Old Apr 28, 2004 | 04:31 PM
sal_blkej2's Avatar
Default ignition coil?
how can i tell if the ignition coil is bad on a 95 gsr? i wanna make sure its just the ignition coil before i go and buy a whole new distributor. any help would be greatly appreciate. thanks, Sal
Old Apr 28, 2004 | 08:32 PM
sal_blkej2's Avatar
did a search but nothing on how to check it. anyone?
Old Apr 28, 2004 | 09:54 PM
timmy8151's Avatar
Default Re: (sal_blkej2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sal_blkej2 &raquo;</TD></TR><TR><TD CLASS="quote">did a search but nothing on how to check it. anyone?</TD></TR></TABLE>
I don't have my Helms on me, but to check the coil you're going to need to check the resistance across the primary and secondary connections.
Using an ohm meter to test the resistance should be:
Primary winding resistance
0.6-0.8 ohms
Secondary winding resistance
12.8K- 19.2K ohms
Old May 5, 2004 | 06:26 PM
zilverz's Avatar
Default Re: ignition coil? (sal_blkej2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sal_blkej2 &raquo;</TD></TR><TR><TD CLASS="quote">how can i tell if the ignition coil is bad on a 95 gsr? i wanna make sure its just the ignition coil before i go and buy a whole new distributor. any help would be greatly appreciate. thanks, Sal</TD></TR></TABLE>
me and Jet Black have bad ignition coils but they still ohm'd good
Old May 7, 2004 | 02:33 AM
DragInteg's Avatar
From: MY GIRLFRIENDS MOMS HOUSE, NEW BERLIN, WI, USA
Default Re: ignition coil? (zilverz)
What symtoms are you having that make you think it is your coil? Sputtering after warm or all the time?
Old May 7, 2004 | 09:54 AM
zilverz's Avatar
Default Re: ignition coil? (DragInteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DragInteg &raquo;</TD></TR><TR><TD CLASS="quote">What symtoms are you having that make you think it is your coil? Sputtering after warm or all the time? </TD></TR></TABLE>
Checked absolutely everything with distributor,ecu, wiring everything checked fine. Swapped ignitor. Still NO SPARK. Hooked up external ignition coil SPARK. Jetblack had the same problem as me. Coil ohmd good. He took his out it was burnt on the inside warped casing .. hooked different coil up he got spark ...
both of our coils OHM'd within spec according to the Helms
crazyc@SRTmotorsports
Mar 12, 2007 03:14 AM
Rex_Ryder
Jan 12, 2005 07:56 AM
Charlie Moua
Mar 23, 2004 05:13 AM
Shakes
Dec 19, 2003 06:54 PM
n0 iNTegRiTY
Oct 15, 2003 03:20 PM
