Idle question
Old Dec 25, 2010 | 07:33 PM
Ramon96LS's Avatar
Default Idle question
I have a 96 Acura Integra...fresh motor and up until a couple hours ago could not get it to turn on...Now That it does turn on it idles extremely high.
Any ideas on what it could be?
Old Dec 25, 2010 | 07:41 PM
hatmanafro's Avatar
Default Re: Idle question
Some sort of vaccum leak?
Old Dec 25, 2010 | 07:50 PM
mouab18c1's Avatar
Any Cel? What was the cause of the car not starting?
Old Dec 25, 2010 | 08:19 PM
Ramon96LS's Avatar
I didnt leave the car on long enough to notice CEL...but it wasnt starting due to the ground on the thermostat housing not being tight lol!
Old Dec 25, 2010 | 08:20 PM
Ramon96LS's Avatar
I keep checking the vacuum hoses...And I will check again I know its probably something so simple like that ground haha
Old Dec 25, 2010 | 08:23 PM
hatmanafro's Avatar
Im a newb and all but is there an idle control valve? Maybe its dirty or something.
Old Dec 26, 2010 | 01:54 PM
earfejj's Avatar
When the motor was built did you take off the intake? If you did it could be a bad intake gasket. That can cause high idle. Or the idle is just wayy off.
http://www.team-integra.net/sections...?ArticleID=195
Old Dec 26, 2010 | 08:33 PM
Ramon96LS's Avatar
i put a brand new head gasket torqued to specs. When i start it..sounds like I stab the gas. Im sure it would idle at redline if i left it on
Old Dec 26, 2010 | 10:52 PM
earfejj's Avatar
Yea, not head gasket but "intake" gasket.
Old Dec 27, 2010 | 03:05 AM
Ramon96LS's Avatar
Yeah I took the Intake off my bad...replaced the gasket with a new one. I was thinking that was it because im leaking fluid from the water passage on the intake.
Old Dec 30, 2010 | 12:24 PM
Ramon96LS's Avatar
Bump Have not had time to work on my ride but was hoping someone could give me a clue as to why my car doesnt idle
ejvtec
Jan 26, 2011 07:33 AM
twentyhurtz
Jan 16, 2009 08:30 AM
pimpami333
Feb 13, 2007 10:30 AM
saikouEF8
Jun 15, 2006 04:31 AM
