Idle problems please help
Old Jan 26, 2005 | 05:35 PM
JDM90SiR's Avatar
Default Idle problems please help
Ok got a 1990 Acura integra for my little brother for his first car. Got it for next to free but it has 220 thousand miles but runs great and is in good shape. One problem.
It idles high then low back and forth. it will not just idle at 600. It will be at 600 then go to 1200 then back to 600 and so on.
any ideas? PCV, Idole control sensor?
Old Jan 26, 2005 | 07:02 PM
JDM90SiR's Avatar
Default Re: Idle problems please help (JDM90SiR)
Please help
Old Jan 26, 2005 | 08:24 PM
pubestripe's Avatar
clean the pcv, and check the throttle cable. u can adjust the idle with a screw on the TB. is it throwing any codes?
Old Jan 27, 2005 | 03:46 AM
JDM90SiR's Avatar
Default Re: Idle problems please help (pubestripe)
No engine codes yet.
Old Jan 27, 2005 | 03:52 PM
JDM90SiR's Avatar
Bump for any other suggestions
Old Jan 27, 2005 | 08:38 PM
jdmjohnny's Avatar
check under ur throtle body...take off ur fast idle take it apart..inside is a plastic screw..tighten it all the way..that will def take care of it
Old Jan 27, 2005 | 08:44 PM
virusiidx's Avatar
iacv?
Old Jan 27, 2005 | 08:58 PM
spog's Avatar
Default Re: Idle problems please help (jdmjohnny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmjohnny &raquo;</TD></TR><TR><TD CLASS="quote">check under ur throtle body...take off ur fast idle take it apart..inside is a plastic screw..tighten it all the way..that will def take care of it </TD></TR></TABLE>
this is correct
xls421
Feb 10, 2012 10:28 AM
Dirtfall
Feb 1, 2007 08:54 AM
eg6nes
Feb 21, 2005 03:57 PM
kihun_cha
25
Aug 5, 2004 09:49 PM
quik2kSi
Dec 27, 2003 09:04 AM
