idle problems
Old Apr 23, 2008 | 11:39 AM
soldado_14's Avatar
Default idle problems
i've taken off and cleaned my iacv off and replaced the vacuum hose running to it. now my teg sounds like it's bogging on idle. should i now assume it's the tps? need some advice g's. thanks
Old Apr 23, 2008 | 12:05 PM
Jimmy's Avatar
Global Moderator
What did you clean the IACV with?
Was it doing it before?
what is the car idleing at now?
Under the hood is a fusebox.. in that fusebox there is a fuse that is 7.5amp backup fuse..
Pull that fuse for 15-20 seconds and it will reset your idle..
See if that works, if not..
Try cleaning the FITV
https://honda-tech.com/zerothread?id=1564019
Old Apr 23, 2008 | 12:19 PM
soldado_14's Avatar
i'll try that man. with throttle body cleaner. it was so burnt. filthy. now it's bogging around 2 to 2500
Old Apr 23, 2008 | 12:21 PM
soldado_14's Avatar
also having a horrible time with this blinker issue. my four ways work the brakes work, the bulbs arent burnt and still chale. the switch works for the high beams works so i don't assume it's that.
Old Apr 30, 2008 | 12:10 AM
soldado_14's Avatar
didn't really do anything.
Old Apr 30, 2008 | 10:20 AM
A L I A S's Avatar
Default Re: (soldado_14)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soldado_14 &raquo;</TD></TR><TR><TD CLASS="quote">also having a horrible time with this blinker issue. my four ways work the brakes work, the bulbs arent burnt and still chale. the switch works for the high beams works so i don't assume it's that.</TD></TR></TABLE>
oh god im going through this right now as well, and no one knows a god damn thing about it!!!! im 99.99% sure its a bad hazard switch if thats not it i may have to shoot my self and end my misery!!! good luck
Old May 12, 2008 | 10:51 AM
soldado_14's Avatar
**** me too. i don't even want to try to rip that button off when i know for sure that it's gonna break as soon as i try to take it off.
Old May 12, 2008 | 06:42 PM
lmike6453's Avatar
if you do, pry from the bottom middle, going upward
cafka184
Honda Civic (2001 - 2005)
May 2, 2014 11:08 AM
andybmuzik
Sep 14, 2011 02:32 PM
jah.tien
Jul 14, 2010 10:37 AM
Mr. LS VTEC
Oct 25, 2006 05:43 AM
SLOAZZ95
Aug 13, 2004 09:34 AM
