Idle Problem!
Old Nov 10, 2010 | 01:27 PM
Hitmo's Avatar
Default Idle Problem!
Hi everyone,
Had a search couldn't find anything specific to my problem, I recently had to replace some of the hoses on my engine so while the coolant was out I removed the IACV to clean it out. Followed the guide on here exactly except I used intake and carb cleaner instead of brake cleaner, and let it dry out for 2 days indoors, then reset the ecu.
Now the car hunts around 1200-1500, whereas before it was fine most of the time just idled a bit high on occasion so I'm stumped why a cleaner IACV is causing more problems, I guess if it aint broke don't fix it :roll:
Also might be worth mentioning that my throttle cable is a little loose but this should make the idle lower if anything!
Heres a pic of the IACV after I cleaned it if it helps:
The car is a 96 spec JDM DC2 Type R
Thanks in advance,
Hitmo
Old Nov 10, 2010 | 01:43 PM
Hitmo's Avatar
Default Re: Idle Problem!
Just realsed this is in the wrong section, mods please delete I've started a new one in the ITR section.
crxguy406
Sep 10, 2015 03:56 AM
Hitmo
Nov 14, 2010 08:30 AM
SoB NiG
Jan 21, 2010 07:23 PM
immalooser
Feb 18, 2009 05:23 AM
majek
Jul 16, 2005 08:22 PM
