Idle problem
Old Jul 15, 2005 | 10:51 AM
majek's Avatar
Default Idle problem
I have a 96 honda accord with a 94 h22 and my car idle between 1500- 3000rpm s up and down no matter if cold or warm. I disconnected the iacv and the idle went down 1200-1500rpm stills goes up and down between these rpms, So what could be the problem.
Old Jul 15, 2005 | 11:43 PM
deserthonda's Avatar
Default Re: Idle problem (majek)
possible vaccum leak. accell cable too tight,
Old Jul 15, 2005 | 11:48 PM
The_Todd's Avatar
Farts in the shower
My guess would be either a vacuum leak or a dirty iacv screen. Take off the bolts/screws on the iacv and clean the iacv with brake cleaner or replace the iacv if the problem persists.
Old Jul 16, 2005 | 02:49 AM
Duane_in_Japan's Avatar
Do a search for this article with my name on it.
Idle Surge (I've searched and read everything .. now what?)
In the Accord section.
Old Jul 16, 2005 | 08:22 PM
ram0869's Avatar
Default Re: Idle problem (Duane_in_Japan)
dont know much about the h22 but my 96 lx {f22b2} has an egr system, used to idle rough at 1500 and above. problem solved after i cleaned the whole intake manifold thorough clean up, took everything apart cleaned it real good, especially the egr system (was clogged with carbon deposits), now it idles normal at 750 and it feels better and responds better
cfoland
Feb 18, 2011 07:57 PM
dth0ng69
25
May 18, 2009 08:30 AM
Jeff_B
Feb 7, 2005 06:51 PM
