Idle problem
heres the deal...lastnight i start my car and my idle was below 600rpm the engine was about to die... i check the timing its fine but the rpm was still da same....help!
Clean your IACV. Do a search, and there's a how-to on this. Could be dirty. If everything is fine, perhaps just adjust your idle with the adjustment screw on the throttle body.
Do you have any modifications? Vacuum leak somewhere? Throwing any codes?
I hate everything
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shamoo »</TD></TR><TR><TD CLASS="quote">Clean your IACV. Do a search, and there's a how-to on this. Could be dirty. If everything is fine, perhaps just adjust your idle with the adjustment screw on the throttle body.
Do you have any modifications? Vacuum leak somewhere? Throwing any codes?</TD></TR></TABLE>
^^Seriously, you know everything lol.
