idle control system malfunction
Old Mar 19, 2007 | 06:48 PM
jdmmachine's Avatar
Default idle control system malfunction
i was driving today when my car started to feel a little sluggish, it was idleing weird at the red light, then off the light it started bucking, check engine light went on. I pulled into a parking lot, and shut off the car. started it back up and it idled fine, drove it home, hooked it up to my scanner and got a idle control sytem malfunction code. I ereased the code and took my car for a good rip, running fine , check engine light didnt go back on. Any ideas what the cause of this code is? TBS sensor? vacuum line?
Old Mar 19, 2007 | 06:50 PM
jdmmachine's Avatar
Default Re: idle control system malfunction (jdmmachine)
btw, its a 2000 LS
Old Mar 19, 2007 | 07:25 PM
jdmmachine's Avatar
bump
Old Mar 19, 2007 | 08:02 PM
dc4_wHORE's Avatar
Soldering Iron Wizardry
my 2000 LS had the same problem for a little while, i replaced the tps sensor, but it didn't help... turns out it was my idle air control valve (IACV), i highly suggest you clean yours (i think theirs a how to thread on HT), because new they are close to $200 new.... i hope this helped
Old Mar 19, 2007 | 08:05 PM
jdmmachine's Avatar
Default Re: idle control system malfunction (dc4_wHORE)
thanks man, i'll check out that thread
Old Mar 20, 2007 | 07:08 PM
dc4_wHORE's Avatar
no problem, you might also try picking up a haynes book for your car, mine has came in handy many times
jeff gonzalez
10
Jun 27, 2019 10:16 AM
bennyv613
Jun 16, 2009 06:18 PM
ap1lvr
Oct 27, 2006 12:13 AM
DannyITR
Jul 21, 2004 05:10 PM
civicboisi
Apr 16, 2003 09:01 PM
