idle control problem help[!!!!!!!!!!!!!!!!!
Old Feb 12, 2003 | 03:36 PM
blkrice's Avatar
Default idle control problem help[!!!!!!!!!!!!!!!!!
I just got a skunk 2 intake manifold installed and since the install i have had a messed up idle it stays at 1500 then goes to 1800 then drops and makes a bogging sound, the when you put your foot on partial throttle it bobs between the two when you engage the clutch and are driving as soon as the rpms are between those rpms it bucks....i have just noticed a slight crack around the tps sensor plug could this be the culprite?
Old Feb 12, 2003 | 03:38 PM
Chris's Avatar
Default Re: idle control problem help[!!!!!!!!!!!!!!!!! (blkrice)
are you getting a CEL code?
http://www.c-speedracing.com/faq.php
Old Feb 12, 2003 | 03:53 PM
97gSrkId88's Avatar
either the tps or the idle control valve. that what i think.
da9crxsi
Jun 4, 2012 09:52 AM
hondastrtracr
May 1, 2006 09:10 PM
JDMkidGSR
Nov 15, 2005 04:59 AM
Lowtightcivic
Feb 1, 2004 01:38 PM
