iacv problems
Old Jul 30, 2009 | 09:40 PM
97redteg's Avatar
Default iacv problems
well i guessing i my idle air control valve is broken because when i start my car it sometimes dies or idles really high when started around 1800-2100 till the engine warms up then goes to normal, or it could be a vacuum leak. I have an obd1 computer p75 manual ecu with a jumper harness to obd2 engine harness with a od1 dizzy with a jumper from obd2 engine to obd1 dizzy, but im still using a obd2 3 wire iacv. this might be the problem itself or would my ecu jumper cable take care of this. Im looking to replace it anyways and wtih this hybrid setup i was thinkin of using an obd1 iacv from a civc and cutting my obd2 engine harness and attaching an obd1 iacv harness matching color with color and exclude the third useless wire. Would this be a good solution or should i stick with and obd2 iacv, and what iacv are interchangeable between Hondas. or should i use that civic one or stick with an integra iacv.
thanks
Kdx
Feb 26, 2018 08:08 AM
fabworxs
Jan 21, 2011 06:48 AM
jdmshawn95
Jan 14, 2011 11:12 AM
JDM_Certified
Feb 23, 2010 05:05 AM
sol-oto
Sep 1, 2009 12:43 PM
