IAC Question
Hey guys I have 91 Integra with a B20B engine and am using a B18A1 manifold. My IAC is leaking where that plate bolts onto the bottom of it. I looked and where that plate bolts to the IAC is all wet around there. Is there a gasket that might be bad on it? If so where can I find one?
Bump. Ok I see that there is a gasket in there. I cleaned up the surface around where the plate bolts to the IAC. The gasket is not available at the dealer so what I did was put ultra gray around the outside of the gasket and put the plate on. I'm going to let it cure until tommorow then try it. Anyone have any input?
zx92027xz
Aug 15, 2010 04:09 PM
r0cket247
Jan 15, 2004 04:21 PM
