IAC problems....please help
Old May 7, 2004 | 04:24 PM
delsolrob's Avatar
Default IAC problems....please help
My car is running like crap, every now and then it will just die at idle and I have to try to drive like I have three feet(one brake, one clutch and one to keep the RPM's above 1500). it makes this funky loping sound and the check engine light comes on...I checked the code and it is 14 (IAC). how can I tell if it is a bad IAC, a wiring problem, etc?
I appreciate any help I can get. Thanks
Old May 7, 2004 | 07:27 PM
stumpyf4's Avatar
Default Re: IAC problems....please help (delsolrob)
Probably sticking... pull off the IAC and clean it with some carb or throttle body cleaner. Clean the area around it and the throttle plate while you're at it.
Efjams24
Jul 22, 2012 02:00 PM
88hondacrx
Oct 28, 2006 12:49 PM
rorik
May 22, 2006 09:49 PM
jbell
Sep 26, 2005 11:04 AM
The G2 Racer
16
Jan 23, 2003 05:23 AM
