i need help ! damn speedometer
Old Dec 5, 2008 | 02:26 PM
mr_loy's Avatar
Icon2 i need help ! damn speedometer
ok so my speedometer is weird.. its a CDM one and it came with the car.. ive had the car for about 2 years now and the KPH doesnt work sometimes.. like it wont go up at all then out of no where it will bounce to my speed.. then it will go back to zero.. so i cant tell how fast im going by looking at it.. can someone help me with this problem.. i know its not big but ehh haha.. i dont like it.. im driving on the freeway and im zooming by cars but when i look at my speedometer im reving like 4k and going 0khp... ahha
Old Dec 5, 2008 | 03:14 PM
mr_loy's Avatar
anyone?
Old Dec 5, 2008 | 03:33 PM
mr_loy's Avatar
man it sucks not knowing how fast im going
Old Dec 5, 2008 | 04:09 PM
slaminsam's Avatar
its one of two things the vss or the cluster itself.
Old Dec 5, 2008 | 04:17 PM
mr_loy's Avatar
vss?
Old Dec 5, 2008 | 04:18 PM
majinsoftware's Avatar
or
gearbox speed gear(inside gearbox) or wiring between vss(vehicle speed sensor plugs into gearbox on outside of casing) and cluster.
Old Dec 5, 2008 | 06:29 PM
bonstokLS's Avatar
VSS= Voltage Speed Sensor. I know because I read a thread about it.
Old Dec 5, 2008 | 07:07 PM
And wheres the voltage come in when you have a cable VSS???
And im sure voltage doesnt need to have its speed measured where a vehicle does.
Read any honda service manual. If you came in to the honda dealers I worked at asking for a voltage speed sensor you would be told theres no such thing, Just like the people that ask for clutch fluid and vtec fluid lol.
Old Dec 5, 2008 | 07:15 PM
bonstokLS's Avatar
Just answering the question. Not sure if it pertains to the car he has or not.
I too would like some VTEC Fluid..and while you are at it..my blinker fluid is low..can you hook it up? LOL
Old Dec 5, 2008 | 07:16 PM
Dogginator's Avatar
Daisy... Daisy...
OP, what year is your car? (94-01 have an electric VSS, 93 and older have a speedometer cable.)
Does your odometer work?
Old Dec 8, 2008 | 10:38 AM
mr_loy's Avatar
it works when my speedometer works.. but when its not working that doesnt work either.. its a 2000 DC..
Old Dec 8, 2008 | 10:39 AM
mr_loy's Avatar
Originally Posted by majinsoftware
and wheres the voltage come in when you have a cable vss???
Read any honda service manual. If you came in to the honda dealers i worked at asking for a voltage speed sensor you would be told theres no such thing, just like the people that ask for clutch fluid and vtec fluid lol.
lol !!!!!
Old Dec 8, 2008 | 10:56 AM
Dogginator's Avatar
Daisy... Daisy...
It could be a bad VSS, bad wire, or bad green film on the cluster. Check the connector on the VSS.
Old Dec 8, 2008 | 10:58 AM
Jimmy's Avatar
Global Moderator
x2.
I've had prongs on the connector break off into the harness plug before..which results in no speedo..
Old Dec 8, 2008 | 11:04 AM
thewrai6th's Avatar
^^ Say what? I guess I just imagined the VSS (part # 78410-ST7-003)...
VSS is the vehicle speed sensor stuck into the top of the transmission, reading the ring gear from your differential.
VSS has power, signal and ground. If you jack up one wheel and spin it, with the ignition on, you should see pulses of 0V-5V-0V-5V on the signal wire.
If the VSS works (which it probably does), then your problem is with the wiring or the cluster. Most likely the cluster is going bad, but another possibility would be the wiring harness grounding out on the back of the intake manifold.
Good luck!
daviss22
Apr 22, 2012 09:19 AM
LAWST
Mar 3, 2005 06:51 PM
imadigitalgod
Oct 31, 2004 02:57 AM
PSU
May 11, 2002 10:30 PM
