I Need help !
Old Jul 30, 2015 | 01:54 AM
Dc2chublu's Avatar
Icon5 I Need help !
I own a 2001 Acura gsr, she's treated me good until just recently I've had trouble where at times she doesn't want to turn back on after a good lil drive, I've changed distributor, fuel pump fuel filter, also main relay, the car runs great and does not shut off while I drive it, it will turn back on after a few cranks, any ideas on what that could be ?
Old Jul 30, 2015 | 09:06 AM
egsleepercivic's Avatar
Default Re: I Need help !
there is a cable\group of wires that run from the ignition to the underdash fuse box, I have had this go bad and cause random issues
When it won't start what happens, cranks no start etc ...
Old Jul 30, 2015 | 10:33 AM
Dc2chublu's Avatar
Yeah it will crank but won't turn over, it will eventually turn on after a few tries, then idiles low th high then back to regular idile
Old Jul 30, 2015 | 11:21 AM
BlackTeggy's Avatar
Coolant temperature sensor?
Old Jul 30, 2015 | 11:37 AM
Dc2chublu's Avatar
It reads tempeture fine, the needle stays stationary when it's reaches the ideal temp
Old Jul 30, 2015 | 02:30 PM
wunfstgsr's Avatar
Loved
Community Favorite
Sounds like a bad ICM in the distributor, was the other distributor you used new or used?
Old Jul 30, 2015 | 02:41 PM
Dc2chublu's Avatar
The other distributor was oem just had a new cap and rotor, and it had the same symtoms that why I got a brand new one thinking that would solve the problem
Old Jul 30, 2015 | 02:57 PM
wunfstgsr's Avatar
Loved
Community Favorite
check your spark plugs maybe there super corroded or something
Old Jul 30, 2015 | 03:39 PM
Dc2chublu's Avatar
I was looking at the distributor a couple of days ago, while I was there I looked at the spark plugs and there still very new no brown residue
Old Jul 30, 2015 | 03:56 PM
are all your engine bay grounds clean and tight ?
Old Jul 30, 2015 | 03:57 PM
wunfstgsr's Avatar
Loved
Community Favorite
check that thermostat ground.
Old Jul 30, 2015 | 04:20 PM
Dc2chublu's Avatar
Those are my two grounds thermostat and the motor, they look ok to me what you think ?
Old Jul 30, 2015 | 07:04 PM
wunfstgsr's Avatar
Loved
Community Favorite
They seem fine it still sounds like its a ignition/spark issue.
Old Jul 31, 2015 | 05:55 PM
BlackTeggy's Avatar
had a similar issue in my Mustang, had to remove the distributor and change the PIP Sensor (Profile ignition pickup) check to see if you have one in your Dizzy.
Old Jul 31, 2015 | 06:04 PM
Dc2chublu's Avatar
I'm not to sure if Honda has that, I think for Honda it's a icm (ignition control module)
Old Jul 31, 2015 | 06:06 PM
BlackTeggy's Avatar
oh ok. im new to Hondas. insuring my Teggy when i sell my Mustang.
im beginner JDM much learning to do
Old Aug 2, 2015 | 01:07 PM
tamboo's Avatar
10 Year Member
Starting Problems
Advanced Ignition Troubleshooting - Team Integra Forums - Team Integra
Old Aug 2, 2015 | 05:23 PM
Dc2chublu's Avatar
I'm really thinking it's the ignition lock cylinder, I'm thinking of purchasing this one, but my key has a chip in it, am I gonna have to swap over the face of the old one over to this new to make it work ? Or will these new keys work just fine ?
Old Aug 4, 2015 | 11:45 AM
I would try the cable first its much cheaper if you are not 100%
STANDARD MOTOR PRODUCTS US502
Old Aug 7, 2015 | 04:15 PM
Dc2chublu's Avatar
I believe this was the source guys and since I've had put it on, the car seems to turn right on, so thanks for the help
Old Aug 8, 2015 | 11:14 AM
wunfstgsr's Avatar
Loved
Community Favorite
So it was a hacked up ignition harness causing the issue?
Old Aug 8, 2015 | 11:29 AM
Dc2chublu's Avatar
Yeah It's seems like that was the issue, because ive been driving it around and so far so good, I also had put brand new ngk spark cables
Old Aug 8, 2015 | 12:37 PM
wunfstgsr's Avatar
Loved
Community Favorite
Cant go wrong with NGK cables!
Old Aug 10, 2015 | 09:11 AM
They probably at some point had an aftermarket alarm installed and hacked it
kingnothingftw
Mar 17, 2015 03:30 PM
Yvettecands
Jan 7, 2014 09:50 AM
ToTriggerHappy
Jun 8, 2010 07:52 AM
dorkzracing
Dec 19, 2008 07:11 AM
