i just put a ls head on my car and now it's not idling y ????
Old 03-09-2008, 12:17 PM
vtechachey's Avatar
Default i just put a ls head on my car and now it's not idling y ????
i got the car to idle but now it is knocking
i did a video of the car running lmk what it sounds like to u
http://myspacetv.com/index.cfm...95053
Modified by vtechachey at 2:27 PM 3/11/2008
Old 03-09-2008, 12:23 PM
SuckMyDOHC's Avatar
a LS head onto what block in what car with what ecu?
Old 03-09-2008, 12:31 PM
vtechachey's Avatar
Default Re: (SuckMyDOHC)
on to a b20b block car is a civic and a ls ecu
Modified by vtechachey at 4:35 PM 3/11/2008
Old 03-09-2008, 12:32 PM
strtrcr77's Avatar
Did you properly install all the sensors and vacuum hoses back on the intake manifold?
Old 03-09-2008, 12:39 PM
vtechachey's Avatar
Default Re: i just put a ls head on my car and now it's not idling y ???? (vtechachey)
yes all of that **** is on i just put a ls head on my boy's car and it runs good so i know what i am doing
Old 03-09-2008, 12:46 PM
vtechachey's Avatar
i did jump timing so that is y i pulled off the head to see if i bent the valves but i did not bent the valves and i got the head looked at and it's still good so i just put it back on
Old 03-09-2008, 01:28 PM
SuckMyDOHC's Avatar
If its not running right, you obviously didn't do it right. Double and tripple check all your vaccum lines
Old 03-09-2008, 01:57 PM
vtechachey's Avatar
i am going to time the cam's and **** right know and see what happens
Old 03-09-2008, 06:18 PM
vtechachey's Avatar
can my block be shot ????
Old 03-10-2008, 08:57 AM
vtechachey's Avatar
ok i got the car to idle and did all of the timing but now it's ticking
Old 03-10-2008, 10:13 AM
lmike6453's Avatar
if it's ticking i would do a valve adjustment and check fuel injectors
Old 03-10-2008, 10:15 AM
g2daturbo's Avatar
Default Re: (lmike6453)
valve adjustment!!
Old 03-10-2008, 03:04 PM
vtechachey's Avatar
it's not just a lil tick
Old 03-11-2008, 03:34 PM
vtechachey's Avatar
sum one
Old 03-11-2008, 03:44 PM
DA_9's Avatar
is it like tick tick tick tick every couple of seconds but consistent? Does the ticking become faster with higher rpms when you rev it up? If so its the valves. A shot block would knock not tick two very different sounds.
Old 03-11-2008, 03:53 PM
vtechachey's Avatar
yes it's consistent ticking and the ticking dose become faster with higher rpms and i just got the head and the valves are good i don't now what it can be
Old 03-11-2008, 05:58 PM
vtechachey's Avatar
can it be the valves are shot ?????????
Old 03-12-2008, 08:07 AM
vtechachey's Avatar
if it's not valves and it's not the block whta can it be?
civictype-r
Northeast (Sales)
03-07-2007 02:13 PM
Nors
06-06-2006 03:50 PM
herde1724
11-16-2004 10:16 AM
boostedcvc
10-22-2004 01:54 PM
xstalkrx
03-15-2003 08:24 PM
Quick Reply: i just put a ls head on my car and now it's not idling y ????
